Fender mount racks
Old Dec 29, 2007 | 12:44 PM
GPHDXLC's Avatar
GPHDXLC
Default Fender mount racks
Any of you have solo racks that mount on the rear fender?
Do they work o.k., or are they to flimsy?...
GP.
Old Dec 29, 2007 | 12:50 PM
Doug45601's Avatar
Doug45601
Default RE: Fender mount racks
I got a new one off ebay.. fits where the solo seat attaches and then where the 2 up seat would attach on a 92-03 model.. Easy fit and contours to the fender nicely.. Flimsey, no but it is not "rock solid" since there are only 2 attach points so you can wobble it from side to side with some effort.
It turns out it's not what I was really looking for "in looks" for my bike so I removed it.... Want to buy it?? just 28.00 shipped to your door by Pri=mail
Old Dec 29, 2007 | 04:29 PM
GPHDXLC's Avatar
GPHDXLC
'Doug'
Thanks, for the info.
In 04 they changed the attach points on the fender. One concern I have is they might look cheap on my 06 Custom. Any opinions on that? If some one has a pic of one on there bike, that would be cool...thanks.
Old Dec 29, 2007 | 05:16 PM
Dorkman's Avatar
Dorkman
The Harley racks are well made and look pretty good. I would recommend a detachable one that works with a backrest. They also have a detachable that works with a solo seat, but I believe it needs docking hardware as well.
Old Dec 29, 2007 | 11:47 PM
jackofhearts's Avatar
jackofhearts
The harley one is nice, but the Motherwell one is also, a little smaller and not easily detachable, it looks custom with a contour of the fender. See J&P on line, an then look on ebay and the like.
Old Dec 30, 2007 | 01:34 PM
ride2tires's Avatar
ride2tires
I like this one. Got 'er from JP.
Old Dec 30, 2007 | 03:23 PM
JosephGarcia's Avatar
JosephGarcia
ORIGINAL: Doug45601
PM me with pics, im very interested in it, but i got a 1988. (i dont mind drlling a new hole to fit it,) but id like to see pics, thanks
Old Dec 30, 2007 | 04:39 PM
Blk XL50's Avatar
Blk XL50
This one works fine from Motherwell and is pretty stable. However I would not want to load anything to big, because as said before, only two attachment points.
Old Dec 30, 2007 | 05:22 PM
Lone Watie's Avatar
Lone Watie
I have a bobtail fender rack for my 08 Fat Bob. It's solid and functional, but won't hold a lot of stuff and is only rated at I believe 10lbs. Its good for my lunch box or jacket, but won't do on a long haul. Going to get the luggage rack for the detach. backrest for overnighters. It looks good though - front mount goes in with the back of the seat mounting hardware, and the back of the mount had to drill into lower part of plastic license plate holder. Was a fairly non-invasive procedure, can be removed without any noticeable change, other than two holes in the license plate holder, which you'd have to know where to look to see.
[IMG]local://upfiles/48997/3F9A86262EED49F3B953BFA611C0BCB9.jpg[/IMG]
Old Dec 30, 2007 | 06:35 PM
jag1886's Avatar
jag1886
I put a Motherwell on my wifes bike it works OK but it only has a load rating of 10 LBS. I think it's primarily a decoration but it does keep the top of the fender from getting any scratches.
