Changing Grips
Old Dec 31, 2007 | 10:42 AM
SeanS's Avatar
SeanS
Default Changing Grips
For changing the grips, whats the best way to get the left grip off? Do you have to cut it off and there's no way to use the stock grips on a new bar?
Old Dec 31, 2007 | 10:49 AM
rh8234's Avatar
rh8234
Default RE: Changing Grips
I've been able to get several off by just twisting them back and forth. At first it feels like they won't budge, but keep at it and they will eventually break loose. If that doesn't work, try one or all of the following. Slip something like a thin screw driver between the grip and handlebar, blow compressed air between grip and bar, spray wd 40 between grip and bar.
Old Dec 31, 2007 | 11:28 AM
Nick's Avatar
Nick
I was looking at the new jp cycles cataloue and was thinking the same thing ...how do the new one attach.? do you have to connect any wires for the throttle
Old Dec 31, 2007 | 11:30 AM
SeanS's Avatar
SeanS
For the right grip, once you get the controls off the grip kinda just falls off be careful though cause they're two little brass rings that the throttle and idle wires go into. I've also heard there can be problems with smashing the turn signals if you're not careful. As all diy projects go, if you take it slow and be careful you should be okay
Old Dec 31, 2007 | 12:56 PM
Motor Mark's Avatar
Motor Mark
I just changed mine a couple days ago, (Kuryakyn Iso-grips) Thanks Santa! They came with good instructions, including a warning about the throttle cable ferrules (SP?) not being connected. Good info as my dumb azz woulda' lost at least one! LOL.
Left side is piece of cake. You may or may not have to slice it, but if you wanna get it off in one piece, be sure you loosen the switch control as there is a ridge in the grip that fits in there. Maybe it will twist off. What you gonna do with an old pair of grips anyway?
You have to glue the new grip on and you will want to cover anything below the work area or you might make a mess of things. (one less decent pair of Levis here [:-]) At least it wasn't on the paint. Hope this helps
Old Dec 31, 2007 | 12:59 PM
SeanS's Avatar
SeanS
Ended up getting the grip off the left side of the night train by just wiggling the crap out of it and some goo gone, no slicing required
Old Dec 31, 2007 | 02:11 PM
principalman's Avatar
principalman
I bought the narrow ring grips from HD. The instructions called for cutting the left, which I did. The right side was actually easier than the left for me. Whole thing took about 30 minutes. Good luck...
Jimmy
Old Dec 31, 2007 | 05:24 PM
carpet dude's Avatar
carpet dude
to remove the left grip just pry the lip a little and use a shot of carb cleaner/w the red straw work back and forth she'll slide right off, clean off well,to use over put some contact on it and slide it back on.
Old Jan 1, 2008 | 01:31 PM
motor134's Avatar
motor134
Cleaning is very important.
larry harding
Aug 1, 2014 08:13 AM
StrokedNBored
Aug 5, 2013 07:28 PM
don g
Oct 3, 2011 02:31 PM
Kansasjase
Oct 30, 2009 07:05 AM
LoRyder
May 24, 2007 06:16 PM
