screaming eagle ignigtion module?
Old Feb 9, 2008 | 12:23 PM
asylum's Avatar
asylum
Default RE: screaming eagle ignigtion module?
nice looking sporty
I went with twintec tc88a module and have not looked back,best modification that Ive done
what drag bars do you have?
Old Oct 2, 2023 | 09:41 PM
Rakerforked's Avatar
Rakerforked
1st Gear
Default Can y’all tell me what kind of points go here? 97 1200xl
Originally Posted by seven7
stupid ? but what does it do and do i need it? saw one pretty cheap on e- bay.
[img]local://upfiles/19758/B25A6D5B1BA345098311269CC66B0B5E.jpg[/img]
Old Oct 3, 2023 | 08:38 AM
aswracing's Avatar
aswracing
You're missing the cam position sensor. Looks like someone cut it off.
On a 1997, the ignition module is under the left side cover, under the seat. It connects through the harness to the cam position sensor, among other places.
It looks like this:
Old Oct 3, 2023 | 03:25 PM
Rakerforked
1st Gear
Thanks bro- can you tell me the parts I need besides that one/ ??
Old Oct 3, 2023 | 03:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The timing plug is missing, and there appears to be debris accumulating in that area, you have to wonder what has passed through that opening while the plug was missing.
Old Oct 3, 2023 | 04:48 PM
John Harper's Avatar
John Harper
Looks like you need:
32400-80B Sensor Plate (Still Available!) $85.99 at Ronnie's HD
Timing Rotor (or clean yours up?) Obsolete, but probably available somewhere. There probably is an aftermarket version.
Timing Plate Studs (2 needed) also obsolete, but probably available
Is your ignition module still on the bike? If they took the sensor, they may have taken the module as well.
If they did you can just get an integrated module that all fits in the place where the timing sensor plate is supposed to be. Check to see if you have the original ignition module before you waste your money on the sensor plate.
John
emperor wurm
Oct 20, 2011 11:39 AM
Jhay
Aug 17, 2009 07:06 PM
BB4xl
EVO
21
Jun 3, 2009 10:27 AM
virtualmike13
Oct 3, 2007 04:13 PM
Jimbo1221
Jul 1, 2006 04:36 AM
