I’ve heard and read conflicting information regarding thermal wrapped pipes. Does anyone have any actual experience with accelerated deterioration of an exhaust system due to wrapping? As I understand the mechanics, the exhaust is not really a key part of the cooling physics and the pipes should be able to handleany increased temps. Your thoughts?
i have my pipes wrapped i just did it recently not a whole lot of seat time............i mainly bought it for the looks and the cooling properties....it keeps the pipes a lot cooler than the sheilds that come factory i havent noticed any decline in performance associated with the pipes other than its a lil louder? (and i mean just a touch) might just be me but they seem that way and im runnin stock pipes with baffles cut out.....overall i like it compared to the factory shielding.....
I wouldn't do it. Thermal wrap is put on by several people because it looks cool and some racing machines use it. When it comes to street riding the wrapped pipes store trap moisture and will rust quicker. It's use on race bikes so the extreme heat from the exhaust doesn't damage other components that are near by. Those tend to have nice big trailors and aren't taken out in the rain. Rust isn't such a big problem on those.
I have mine wrapped for about 1000 miles so far and my observations are....
The pipes are a little louder.
My right leg doesn't feel like it is going to catch on fire at at stop light.
Looks good.
The wrap is supposed to keep the pipe hotter on the inside and speed up air flow for better performance.
I am not buying the rust thing because the pipe evaporates any moisture almost instantly. If you are riding in the rain and you pull into the garage, just let the bike idle for a minute and it will all be dry.
I also sprayed mine with the high temp paint for the color and the smell takes a while to burn off.
Rain runs right off mine....they don't hold moisture at all...and I ride in any weather. In fact, they feel like solid ceramic (i used a whole can of the ThermoTec black coating).
You have to coat them right...if you don't, of course they're gonna be messed up. Make sure you get the rest of the pipe, the bracket, and the inlet, too...that way the bluing won't show on the bare part near the top.
And as far as rust...they rust just as easily with water getting trapped under heat shields. So it really doesn't matter either way.
I am confused...does it make it hotter or cooler?????? My understanding about speeding up air flow is that if the pipes were cooler, air will flow better, as hot air has a bigger attraction to cool air (analogy, the cooler the flue on a fireplace , the better the draw of exhaust gases....when I worked around general aviation (small recip. planes) some of the ex. systems took cool outside air in a scoop and blew it over the pipes to cool themto augment the exhaust flow and keep the engine cooler....and these were air cooled engines as well....anywho.............later.....BINNY
ORIGINAL: bhtx
Looks good.
You're right it does cool the outside of the pipes, which is why the wrap is pourous.
It's not that it actually HEATS the inside of the pipe....it just prevents uneven heat expansion and provides better insulation, which produces a more controlled flow and more powerful sound waves....they cannot escape as easily due to insulation and added pressure. Which is why you wet them down, wrap them VERY tight, and let them dry before coating them with the ceramic spray. As it bakes on, it hardens and shrinks even more, almost literally bonding to the pipe.
Flick it with the back of your finger nail, you'll see what I mean...it actually sounds metallic after they've cured. If you've done em right, you should have a hell of a time getting it off, should you ever decide to.
if you use the spray they have it prevents moisture from getting to the pipes so rust isnt a factor....go to DEIs site they gotta installation vid and short explaination.....i did a lil bit of reading before i chose to do it...all in all i like it plan on doing it to my honda soon....just gets harder and harder to grab the car keys instead of the bike keys you know?
