1200n Engine Ping
Old Apr 20, 2008 | 12:16 PM
DEREK71's Avatar
DEREK71
Default 1200n Engine Ping
about half throttle i get an engine ping not sure what it could be wondering if i should check the primary oil level or switch oils it really scares me when i hear it.maybe i should change to a thicker oil any suggestions?
Old Apr 20, 2008 | 12:22 PM
hogsport's Avatar
hogsport
Default RE: 1200n Engine Ping
What octane gas are you using? sounds like you are running 87 and should be 91+
Old Apr 20, 2008 | 12:27 PM
cHarley's Avatar
cHarley
+1 If it is "Pinging" it has nothing to do with oil.
Old Apr 20, 2008 | 12:34 PM
DEREK71's Avatar
DEREK71
should i add octane boost i was thinking if was an oil problem i would hear it all the time but thats not the case.
Old Apr 20, 2008 | 12:54 PM
cHarley's Avatar
cHarley
You didn't answer the question..... What octane are you running?
Old Apr 20, 2008 | 01:07 PM
DEREK71's Avatar
DEREK71
the other day i used regular today i put in premium gas ill see what that does
Old Apr 20, 2008 | 03:19 PM
DannyZ71's Avatar
DannyZ71
ORIGINAL: DEREK71
You may have to go thru a tank or two of 91 octane before it stops. So don't go back to the regular.
Old Apr 20, 2008 | 07:10 PM
pepfan25's Avatar
pepfan25
had simialr prob. sitting at a light i would rev it up and hear a nasty ping. took it back to dealer. they said i had bad gas. they cleaned lines and drained tank. now i only use named brand gas and only high test. been cool ever since.
Sierra977
General Topics/Tech Tips
Jan 17, 2017 02:42 PM
Fobos
Aug 1, 2011 07:17 AM
alyaseen
Jul 20, 2011 10:59 AM
Landi
Oil Archive (no new posts)
Sep 26, 2010 11:06 PM
doorguy2005
May 19, 2010 01:30 PM
