help sissy bar sideplates
Old Apr 23, 2008 | 04:36 PM
trailey97's Avatar
trailey97
Default help sissy bar sideplates
will somebody please post a picture on here of their 883c with sissy bar sideplates
reason bein is ... where i bought mine they are sayin i got the right one but i know there is a better one to put on which goes around my turn signal so i dont have to take it off then put the plates on, then put the lights back on please
Old Apr 23, 2008 | 04:43 PM
sweetroll's Avatar
sweetroll
Default RE: help sissy bar sideplates
Here are the type I have for my '07:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
They go right around the stock light mount.
It looks like there is a rigid mount available as well, which would require you to take off the lights.
What year is your bike?
Old Apr 23, 2008 | 04:57 PM
joel85's Avatar
joel85
Mine are rigid plates. Do NOT have to take off the lights. Just take the screws out of the taillight bracket, slide it in behind, and re-assemble. Looks much better than the detach on the outside as well IMO. Can't take it off..........as easy though. They probably gave you rigid instead of detachable. You would know if they were detachable because instead of just charging you a 1 arm for the rigid, they take an arm and a leg from you for the cost of the detahables.
Old Apr 23, 2008 | 05:02 PM
sweetroll's Avatar
sweetroll
Ya, the one's I got weren't cheap, and I don't really take them off all that often... maybe if I wantedmy passenger to hold on a little tighter
Old Apr 23, 2008 | 05:37 PM
Booey424's Avatar
Booey424
Mine are rigid also.They go around the lights.I put the whole thing on myself.It was very easy
[IMG]local://upfiles/25674/3A49358289584654B9AE7F2144562BEB.jpg[/IMG]
[IMG]local://upfiles/25674/2C6650DBB9E246B1B356838B910BE2B8.jpg[/IMG]
Old Apr 23, 2008 | 11:26 PM
trailey97's Avatar
trailey97
my bike is n 06 custom
heres what the side plates i got look like
preciate the comments back
[IMG]local://upfiles/58940/EFFCD9DCD759482D9FE4E77150C72331.jpg[/IMG]
Old Apr 24, 2008 | 04:22 AM
dbleagle's Avatar
dbleagle
Looks like the right ones to me....
Charlie D.
Old Apr 24, 2008 | 08:42 AM
2WheelThrill's Avatar
2WheelThrill
Same plate I used on my '07 this past weekend. You SHOULD only have to remove the bolt to the lights to slide the plate behine them. However, both my turn signal lights came off the bolt/posts which made the whole task quite a bit more difficult. If this happens, you will need plenty of excess turn wire play (might even have to disconnect them from the rear assembly, I did) in order to get that damn nut tightened that sures up the light to the post.
Having an extra set of hands will help ya not scratch up the paint on the fender - I had to bend and push my fender around a bit to get everything to line-up just right.
Good luck!
Old Apr 24, 2008 | 08:58 AM
Kanzig's Avatar
Kanzig
I have an 06 Custom and I just installed a sissybar/upright/plates 2 weeks ago. Mine are the detachable type though, yours appear to be the rigid type. My install was pretty easy, just had to go slow and steady on removing the bolts. The were torqued on pretty good.
Kanzig
Old Apr 24, 2008 | 02:13 PM
trailey97's Avatar
trailey97
hmmm[sm=confused06.gif] maybe doin this will help with the install lol [sm=alcoholic.gif]
thanks for the help guys
imma give it a shot with on of my buddies this wkend
i knew there were two diff types but the place i bought these from told me there aint
once again this is why i love this webpage thanks
tommyrocks
Feb 24, 2016 10:02 AM
Beerswimmer
Jan 13, 2011 10:50 AM
YellowHawk
Apr 24, 2008 10:54 AM
SIM
Aug 7, 2007 02:45 PM
SoCal Harley
Nov 23, 2005 11:42 AM
