screamin eagle air filter?
Old Apr 30, 2008 | 11:52 PM
jeff442's Avatar
jeff442
5th Gear
Default screamin eagle air filter?
hey i could use some help i bought my 1200c used with the se pipes and air cleaner how do i clean it and does it take oil like a k & n filter thanks in advance
Old May 1, 2008 | 12:28 AM
PigInaBlanket's Avatar
PigInaBlanket
Default RE: screamin eagle air filter?
Depends on the year of your bike. If it's an 04 and newer the SE filter does not need oiled. It can be washed in the sink with dishsoap and I even used Fantastik spray on the really dirty parts. 03 and older I believehad a K&N filter for the SE filter and those would be oiled.
Old May 1, 2008 | 12:46 AM
cosmicHD's Avatar
cosmicHD
To add..K&N now makes a replacement filter for the '04 and later SE AC.
Old May 1, 2008 | 05:34 AM
jeff442's Avatar
jeff442
5th Gear
sorry its an 05 but it still looks like the oval air filter cover as stock so maybe that isnt a se air filter . how can i tell for sure.
Old May 1, 2008 | 06:38 AM
Simon UK's Avatar
Simon UK
The SE air cleaner for an '05 uses the stock cover, but a different backing plate. If you just have a cover and a basically flat backing plate with a gap between itself and your motor you have the SE air cleaner; if the backing plate is a big bulky thing with just a small opening at the front and that fits right up snug to the cooling fins on your engine you have a stock air cleaner.
JonW
2014-2024 Touring Models
Jul 20, 2019 09:52 PM
Remnighttrain
Aug 4, 2009 03:59 AM
Metal4God
Exhaust System Topics
Jun 18, 2008 12:31 PM
SportyPig
Jul 16, 2007 12:10 AM
FXSTBN
May 1, 2007 08:35 PM
