V&HFUELPAK on a Nightster
Old May 8, 2008 | 07:42 AM
mattgnigthster's Avatar
mattgnigthster
Default V&HFUELPAK on a Nightster
Hey guys just wanted to know what people are out there doing to fit thereV&H fulepak on there nightsters since i've dones some reading and find that when I get it, its giong to be a bitch to make it fit under the seat. Any tips on what works for you would be great.
Old May 8, 2008 | 09:41 AM
widgeon's Avatar
widgeon
Default RE: V&HFUELPAK on a Nightster
hi,
it is a bitch 2 fit,but all i can say is take ur time with it,and u'll get there. do'nt lose ur ra g with it.
Old May 9, 2008 | 07:14 AM
07HDnightster's Avatar
07HDnightster
Yes.... Installing the fuelpak is a pain in the ***. Like widgeon said, just take your time and it will be alright.
Old May 9, 2008 | 07:39 AM
Gnight's Avatar
Gnight
Well when I installed my fuel pak, I also installed a spring seat..so I just relocated it in the rear of the engine compartment. Works great so far..wrapped the ECM in heat tape so the pipes wouldn't be melting anything. Work great so far..have about 1k miles on it and still running!
Old May 9, 2008 | 11:54 AM
Nasty Nightster's Avatar
Nasty Nightster
Taking your time and having patience is right. It will fit how the directions say. Big thing is make sure the connector over the battery is facing the correct way.It's a tight fit but can be done. You'll befine.
Old May 9, 2008 | 02:43 PM
Tumtum4's Avatar
Tumtum4
yea it is tight. just take your time. and watch the video a few times. took me 2 hours and about 3 beers
Old May 9, 2008 | 07:31 PM
blackout85's Avatar
blackout85
Also make sure the cables are warm. I was trying to rearrange cable harnesses when installing my power commander in a 30 degree garage, yeah... bitch.
Old May 9, 2008 | 07:39 PM
Bradley Jones's Avatar
Bradley Jones
Can't you just go to the dealer and have them tune the ecu?? or do you need to have some type of fuel management for them to tune it?? I have the fuel pak and I can't say I'm too thrilled at it's function. My bike runs mint but every now and then, not often at all, I get a back fire[:@] If I could do it all over I would have searched for an alternative route. After the pain in the *** that thing was to install I'm ****ing leaving it there till I have to replace it, Or if I swap to some other type of pipe other than V&H I'll toss that piece of crap in the garbage.
Old May 9, 2008 | 11:17 PM
rdss's Avatar
rdss
ORIGINAL: blackout85
I was looking at the Power Commander instructions and it makes it seem like you just drop the new platic base in and throw the Power Commander in it. That sucks that it does not fit that great, or is it the wiring that is the problem?
Old May 10, 2008 | 09:27 AM
pancho's Avatar
pancho
As to installing the FuelPak, I read what seemed to be every post, watched the video multiple times. V&H says it will mount between the frame rails above the battery, the guys who have installed them say take your time it will fit. Ok, here is what I found out, they are all correct, here is what I learned, run the wiring exactly like they do in the video, on the right side of the harness, the connector that is the pain in the butt will fit like they say, there is a bundle of wires that runs along the bottom of the backbone, you need to just grab hold of that bundle and pull it tword you, it would work better if ya do it in a warm room or day, so they give a bit, then take that connector and push it up and back behind that bundle of wires, under the Y the frame makes, and it will fit right in there. The batt strap fits back into place, the batt will slide back in, and you're done. Took me 2 hours and I scratched my head awhile before I got it, does help to watch the video so you see where they slide those wire looms through, but that connector is the item that causes the problems, they just don't explain how to make it fit.
dannym2009
Jul 24, 2012 11:29 AM
09NightsterVB
Jun 15, 2009 08:21 PM
Mister H
May 3, 2008 07:26 AM
xharleyx
Mar 9, 2008 10:18 PM
Nightster38
May 7, 2007 01:11 PM
