Replacement Choke Knob
Old May 10, 2008 | 05:17 PM
titus3:5's Avatar
titus3:5
Default Replacement Choke ****
I am planning something maybe unusual, but I want to try and replace the black plastic choke **** with something like a kitchen cabinet chrome ****. Is this possible to do and if so how do I get the black plastic **** off with out destryong the whole choke mechanism. Ive tryed to pull it off, nope that didnt work, tried twisting it off nope that didnt work either, any other suggestions
Old May 10, 2008 | 05:23 PM
capttawes's Avatar
capttawes
Default RE: Replacement Choke ****
The choke **** is made onto the shaft so spitting it and cutting it off is the only way. Once off youcan take your kitchen **** and drill/tap the side fo a set screw and that will hold it just fine. A better solution is buying a smaller control **** like is used on vintage push/pull auto contols which is smaller/lighter and has a set screw. You can find find them in auto parts stores or through JC Whitney.
Old May 10, 2008 | 05:49 PM
128auto's Avatar
128auto
I broke mine the first month, got a car stereo ****.
Old May 10, 2008 | 11:45 PM
jackofhearts's Avatar
jackofhearts
I took the plastic off with dykes. Replaced with a custom **** w/ set screw, but I have a question. My new **** sticks out about 1/2 inchs at what appears to be a natural resting spot. I can push it in farther, but it wants to come back out. I figure the old **** stopped shorter than my custom one, ...or, am I supposed to get that cable to go in and stay in as far in as possible? Either way doesn't seem to affect the performance or idle rpm. Any thoughts?
Old May 11, 2008 | 12:55 AM
Batley's Avatar
Batley
I use a gas cap for my choke ****.
Old May 11, 2008 | 08:28 AM
Booey424's Avatar
Booey424
I bought the chrome cover from Harley.It looks much better then that black plastic.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old May 12, 2008 | 12:12 PM
Stefan's Avatar
Stefan
ORIGINAL: capttawes
tap the side for a set screw
There is a notch in the shaft that the set screw will set into.
A friend of mine works at a machine shop. We measured up the original **** and shaft, turned a brass **** & drew it up in cad for later production.
I will get the distance measurement (not kept at work), from the notch to the end of the original **** for those who don't know where the original **** stoped.
Old May 12, 2008 | 10:01 PM
jackofhearts
Thanks Stefan, that is the exact information i am looking for.
Old May 13, 2008 | 10:43 PM
Stefan's Avatar
Stefan
The setscrew is .470" from the end of the **** on the **** I made. This puts the setscrew in the center in the notch in the shaft.
The distance from the edge of the notch in the shaft to the end of the plastic **** is ~.3505 as measured with a vernier caliper.
Old May 14, 2008 | 12:00 AM
LoneRyder's Avatar
LoneRyder
[align=left]Local music stores carry Black and Chrome knurled guitar volume ***** that have set screws. Check them to make sure. They can look pretty cool as a choke ****.[/align][align=left][/align]
