Electrical Starting Question
Old Jun 30, 2008 | 10:02 PM
cahiggy's Avatar
cahiggy
5th Gear
Default Electrical Starting Question
My bike has been running like a champ, then today here is what happened. I turned the ingition key on like normal, all the lights light up. I push the start button and the everything goes out. I took off the left side cover, there is a male/female plug with one black wire and one red wire. I giggle the black and red wires and then the lights come back on. When I do this there is a funny noise too. I push the start button and bingo it starts. This has been happing to me the last few times I go to start my bike. I now have noticed that nothing happens when I giggle the red wire, but only giggling the black wire will get all the lights to come back on and then start my bike. Has anyone had this problem, and if so what do I need to do to fix it. O, its a 2004 XL883C Sportster&nbsp\\;if that makes a difference.
&nbsp\\;
&nbsp\\;
Old Jun 30, 2008 | 10:54 PM
loner19532004's Avatar
loner19532004
Stage III
Default RE: Electrical Starting Question
I have a friend that has a '06 Sporster and she was having a similiar problem. In addition to the lights going out the speed ometer would jump and you could hear a strange sound like an electrical sounds. Brought it to the Harley dealership and they said it was a loose connection on the battery. Hope this helps
Old Jul 1, 2008 | 05:26 AM
Thumper26's Avatar
Thumper26
Sportsters are notorious for having loose battery cables.&nbsp\\; My suggestion is to tighten all four points of the positive (red) and&nbsp\\;ground (black) battery cables.&nbsp\\; A physical check is worthless,&nbsp\\;you must ensure their tightness with a wrench.&nbsp\\; If they are in any way dirty or corroded, remove the two cables and clean the contact ends with a wire brush and sandpaper, then reattach and tighten.&nbsp\\; Although the culprit is usually the ground (black) cable, do all four battery cable points of contact.&nbsp\\;
Old Jul 1, 2008 | 07:24 AM
WVHogRider's Avatar
WVHogRider
^ +1 on what Thumper said....and check the&nbsp\\;tender connector, (the black and red wire connector that mentioned under the cover), for&nbsp\\;bare spots, as it could be shorting out. &nbsp\\;&nbsp\\;
Old Jul 1, 2008 | 12:17 PM
rdss's Avatar
rdss
What is the easiest way to tighten the negative wire?&nbsp\\; I got into it when I added the siren to the bike and was a pain to get bolted on and off with out an extra set of hands.&nbsp\\; I ended up kind of balancing it on a knee so that I could use both hands to hold and tighten the wires.
gork
11
Jul 10, 2020 07:11 PM
JD Heath
Electrical/Lighting/Alarm
May 4, 2018 01:14 PM
MartB
Oct 10, 2014 07:23 PM
Max10
May 6, 2013 07:30 AM
johnnyhumble
Dec 31, 2008 10:55 AM
