Transmission Help
Old Jul 1, 2008 | 12:14 AM
DrewWalden's Avatar
DrewWalden
3rd Gear
Default Transmission Help
I have a 99 sportster. Sometimes when in first gear I'll hear a loud clunk or pop noise and the bike will quit accelerating, like its going into neutral for a second. It only does it sometimes. At first I thought the clutch was just slipping, but I think it has something to do with the transmission. Anyone have this happen? Do I just need to change the fluid or is my transmission going out?
Old Jul 1, 2008 | 06:51 AM
Simon UK's Avatar
Simon UK
Default RE: Transmission Help
I would think it is a transmission&nbsp\\;problem rather than a clutch problem.&nbsp\\;Sounds like the gears are jumping out of engagement.&nbsp\\;
Old Jul 1, 2008 | 08:04 AM
95hd883's Avatar
95hd883
when i first got mine i noticed a really loud clunk
&nbsp\\;
when i shifted into first..either from neutral or downshifting..
&nbsp\\;
then my dang primary cover gasket started leaking..
&nbsp\\;
so..(just a suggestion)..go ahead and get yourself a new primary gasket and some blue locktite
&nbsp\\;
and primary fluid...drain fluid take off cover...Check &amp\\; Adjust&nbsp\\;Primary Chain Tension
&nbsp\\;
get it all back together...(don't forget the locktite!)
&nbsp\\;
adjust the clutch per the manual..that's what fixed mine..i get a&nbsp\\;nice tight click now
instead of that loud clunk..
&nbsp\\;
mine is a '95..and had 9,000 miles on it..so it may be time
&nbsp\\;
Good Luck
&nbsp\\;
&nbsp\\;
&nbsp\\;
Old Jul 1, 2008 | 12:43 PM
Ric27's Avatar
Ric27
ORIGINAL: DrewWalden
My 97 is doing the same thing. Just as take off occasionally , maybe 1 out of 10 times it will do this little slip then jerk when it actually engages thing. Very disconcerting. It also has developed a problem down shifting all the way into first. I will check it at a stop and it feels like it is in first and then I take off and I am in 2nd or sometimes even in third. I was thinking maybe the shifting forks inside the tranny?
I on board of a answer on this one. If there are 2 of us with the problem someone else must have been through it.
Ric
Old Jul 1, 2008 | 12:56 PM
cHarley's Avatar
cHarley
2 tips for some of the above problems:
1 - Check the primary chain adjustment, it may be too loose.
2 - Always downshift to 1st gear before the bike comes to a stop.
Old Jul 1, 2008 | 01:08 PM
Sick1200's Avatar
Sick1200
+1 on the chain adjustment, check fluids also.
Old Jul 1, 2008 | 01:49 PM
Ric27's Avatar
Ric27
OK, I have the correct amout of fluid in the case. I just change it being very careful to drain all the old out and replace with the required amount. I just checked the primary chain adjustment. It was just beyond the max play allowed, just over 1 half in. I adjusted it down to 3/8" the short spec number. Will see is that does anything.
thanks guys. I'll keep you posted. &nbsp\\;\\\\\\;
Old Jul 1, 2008 | 07:18 PM
vincentostapowich's Avatar
vincentostapowich
Mine did the very same thing,,tightened the chain,,hasnt done it since.
Old Jul 1, 2008 | 09:00 PM
Ric27's Avatar
Ric27
I went for a 25 mile ride around here on the county roads and had no issues with the slipping in to gear as I started off. I will have to ride a few more times to know if that was the problem. It did seem to shift better as in smoother on the clutch engagement after the shift. I'll post again after I have a few more miles on the adjustment.&nbsp\\;
mulch63
EVO
Aug 1, 2008 02:58 PM
LeadSlinger0311
Great Lakes
Jul 16, 2008 05:41 AM
Billydj
VRSC Models
Jun 30, 2008 09:17 AM
Zipper
Jun 18, 2008 07:57 PM
