Just curious as I am still shopping and cannot find the specs I'm looking for anywhere, what is the weight limit for passengers on an 883c? I'm not light at 6'4" 280 lbs, and I want to know how much weight I could put on the back for a passenger if I got one.
Here is the specs from my 04 883c. \\; Dry weight 579lbs, \\; Gvwr 1001lbs, \\; Gawr front 335lbs, Gawr 666lbs. \\; \\; Once you add your weight and a passengers, sissy bar, luggage rack and bag your right at the max rating. \\; The stock suspension even when ran under the max still bottoms out, not uncommon for the wiring harness in the rear fender to get torn up once you get a aftermarket tire. \\; Im 5'10" 210 lbs and wife is 130lbs, Ive done alot of suspension mods and the bike is alot better but I do mostly 98% one up riding. \\; I would tell you to look for a nice used Electra glide standard.
Killer:
I am on my second sportster. \\; The first was a 2002 XLH 883. \\; I now have a 2005 1200C. \\; I have carried in excess of 500 pounds on both of them without a problem. \\; However, I didn't have the stock shoks on either. \\; I went with progressive rear shocks immediately after purchase.
Hey thanks for the replies guys. I'm really just thinking around town (the girlfriend has her own Ninja), I am seriously considering the 883c. It isn't even that huge of a deal, \\;mainly riding solo, \\;but it might be fun every now and again. Thanks again.
