Progressive suspension query
Old Jun 21, 2008 | 03:52 PM
Photo's Avatar
Default Progressive suspension query
I have an XL1200C and have no problems with the suspension when riding solo (I'm a lightwieght at 126lbs). However, I've recently managed to puruade my wife on the back HOORAY!! (an additional 140lbs).
&nbsp\\;
When two up the suspension is bottoming out on the slightest bump in the road which is a real pain.
&nbsp\\;
From my reading here Progressive shocks appear to be the answer. However, I think I also saw someone mention that you couldnt use the preload adjuster with saddle bag supports, which I have and need. Is this true, and does it apply to all the various rear shocks available or only some?
&nbsp\\;
Grateful for any input and recommendadtions.
Old Jun 21, 2008 | 10:42 PM
GPHDXLC's Avatar
GPHDXLC
Default RE: Progressive suspension query
I have 12.5" Progressive SD shocks. I ride solo 180 lbs they really don't do much to make the bike ride smoother but they did stop the bottoming out. With 2 on it at 266 lbs you may need to get the HD shocks. As for the saddlebag supports, I have them to, and I can still use the preload adjuster just have to be a bit more careful of where you hook the adjuster to the shock, it's no big deal...
Old Jun 22, 2008 | 10:18 AM
rfranz1952's Avatar
rfranz1952
I just installed a set of Progressive 240 HD's about two weeks ago on my Custom.&nbsp\\; I selected the 12" model.
&nbsp\\;
I weigh about 240 - 250, and ride only single.&nbsp\\; I have the progressives set in the middle, and they did smooth the ride quite a bit.&nbsp\\; If I move the preload up one notch, it stiffens the ride quite a bit.&nbsp\\; I haven't yet tried lower.
&nbsp\\;
I like them.&nbsp\\; Easy install, better looking than stock, and greatly helped solve the sore butt issue.
&nbsp\\;
Old Jun 22, 2008 | 10:31 AM
Terp84Alum's Avatar
Terp84Alum
Did you try adjusting your stock shocks yet?
Old Jun 22, 2008 | 03:39 PM
hogsport's Avatar
hogsport
First thing you need to do is adjust your pre-load - it is the part that turns on the bottom - gget t spanner from HD or use xome channel locks &amp\\; leather to turn it to the highest setting (both sides)- you should be ok w/ 270 lb total and stock shocks in regards to bottoming out.
Old Jun 23, 2008 | 02:38 PM
Photo's Avatar
Thanks all, it actually only occured to me to try changing the preload on the standard shocks after posting my initial question (I would claim to have been having a blonde moment, but am so follicly challemged no one woul believe that).
&nbsp\\;
However, I've run into difficulty. I've done loads of searches on google but cant find the adjuster tool anywhere. I bought a so called universal one from a shop over here but its too big. By which I mean the lug fits into the groove on the adjuster ring fine, but the handle hits the belt guard before I've turned it sufficiently.
&nbsp\\;
If anyone has a link to a web site where I can order one I'd be extreemly grateful. Im Englans so it would have to be a site which will ship goods abroad.
&nbsp\\;
Thanks for any help you can give.
Old Jun 23, 2008 | 03:28 PM
ZX2BY2U's Avatar
ZX2BY2U
&nbsp\\;A large pair of channel lock pliers &amp\\; a shop towel to save the chrome are all you really need to adjust your shocks.
Old Jun 23, 2008 | 04:22 PM
Sick1200's Avatar
Sick1200
I bought mine off ebay, but you should be able to put your current adjuster in more than one spot to adjust.
Low E
Jul 18, 2008 12:38 PM
Mud Cut
Jul 10, 2008 01:54 PM
Big Jake
Jun 27, 2008 01:31 PM
soon to be
Jun 16, 2008 03:59 PM
DeckerDude
Jun 9, 2008 10:03 PM
