Speedometer malfunction
Old Aug 26, 2008 | 10:00 AM
shermdog's Avatar
shermdog
Stage III
Question Speedometer malfunction
After not riding for a week (due to Tropical Storm Faye), my electronic speedo will not register over 35mph. Has anyone ever seen such a malfunction?
Old Aug 26, 2008 | 10:17 AM
EricM's Avatar
EricM
One fix would be to pull the speed sensor and wipe the metal shavings off of it. The sensor is magnetic and can accumulate metal shavings.
Old Aug 26, 2008 | 10:58 AM
WVHogRider's Avatar
WVHogRider
It could be from all the moisture where you are at. Mine's done that quite a few times in the past usually after washing it, moisture somewhere in the system. I just pull over, shut it down including turning the key off, and then re-fire it & it's back to normal. Could be the same with yours.
Old Aug 26, 2008 | 01:03 PM
shermdog's Avatar
shermdog
Stage III
thanks for the tips. I am at work right now so hopefully afterwards when I get ready to go it will work fine. I live in Central Florida so I often ride home in the rain so maybe it just got wet and due to the humidity hasn't dried. If not I'll be pulling the sensor out tonight.
Thanks again
tnich501
Sep 5, 2024 08:44 PM
Twilly
Aug 23, 2012 10:08 AM
mays
Jul 28, 2008 07:12 PM
cws176
Jun 1, 2007 01:33 PM
robbitybob
May 6, 2007 08:40 AM
