Big problem need help!!
Old Sep 12, 2008 | 11:01 AM
will227457's Avatar
will227457
Default Big problem need help!!
Ok so I get my new mini apes, I'm all excited I have new cables and everything I need so i start on the clutch side, remove the bars, disconnect the clutch loosen it up all the way, take off the primary cover unhook the old clutch and then unscrew it from the primary....so far no issues...I take the new extended clutch hook it up and then procede to screw it in to the Primary...halfway in it breaks.....the threaded part breaks so I have a little threaded stump and the rest is stuck in the primary....now what do I do?
Old Sep 12, 2008 | 11:17 AM
notfried's Avatar
notfried
um,get the stud out and make whoever you bought the line from replace it
Old Sep 12, 2008 | 11:22 AM
will227457's Avatar
will227457
yeah cant get the stud out with out cutting the clutch cable.....they will prob just think Im a moron or something....
Old Sep 12, 2008 | 11:27 AM
will227457's Avatar
will227457
Originally Posted by will227457
yeah cant get the stud out with out cutting the clutch cable.....they will prob just think Im a moron or something....I was thinkini I'd just finshing hooking up my throttle and idle cables extend the wireing and throwing it in my truck and takin it to the dealer with my tail tucked neatly between my legs....I honestly don't see how I am going to get the stud out with out destroying my primary..
Old Sep 12, 2008 | 11:30 AM
cosmicHD's Avatar
cosmicHD
Can you drill the other piece out?
Old Sep 12, 2008 | 11:33 AM
will227457's Avatar
will227457
I guess I can drill it out I dont want to screw up the threads on my primary though...thast my fear....
Old Sep 12, 2008 | 11:36 AM
Zimbob's Avatar
Zimbob
How hard was it to screw in? If it wasn't too hard, try an easy-out.
Old Sep 12, 2008 | 01:20 PM
Lickety Split's Avatar
Lickety Split
If the easyest way to get the stud out is to cut the cable call the place where you got it and tell them what happened before you cut the cable. Maybe they'll be cool enough to exchange it afterwards.
CVO-RK
Feb 11, 2013 07:42 PM
timruger1
Jul 28, 2012 06:36 AM
Harley Bass
Classic
Feb 21, 2011 07:32 PM
Bluesrider
May 5, 2009 06:48 PM
jeffer60
Dec 15, 2005 07:58 PM
