Handlebars???
Old Nov 3, 2008 | 03:35 PM
utz's Avatar
utz
1 1/4 radious bars very comftable.
Old Nov 3, 2008 | 06:04 PM
iupsig97's Avatar
iupsig97
I have dyna wide-glide handlebars on my sporty and love them. Think they are 10" mini-apes.
Old Nov 3, 2008 | 06:20 PM
HDXXX's Avatar
HDXXX
My bars are from a sportster low.
Old Nov 3, 2008 | 06:36 PM
SHOAT's Avatar
SHOAT
Originally Posted by Kski
Hmm. I might have to look into the dyna's more as I'm going for comfort anyway. I just thought they would look a little bit silly being so much wider on a narrow stock sporty front end. The gas tank already looks out of place with that front end! So since I might be switching gears, what all needs to be done to put those on?
Thanks
To install the Dyna Low bars on a 1200/883C all you will need to do is:
1. Reroute the throttle cables outside of the triple tree instead of through it.
2. Install a longer brake line or you may be able to rebend the metal portion of the brake line (to gain sufficient slack) and relocate the brakeline clip.
The clutch cable and wiring do not need replaced or extended.
Hope this helps.
Old Nov 3, 2008 | 06:47 PM
Kski's Avatar
Kski
Awesome. I'm going to the dealer tomorrow probably to feel the difference in them.
Old Nov 4, 2008 | 02:53 PM
plevine1's Avatar
plevine1
Here's mine with BLACK 13in mini's.
Check it out
http://s424.photobucket.com/albums/pp329/plevine1/
Old Nov 4, 2008 | 03:11 PM
utz's Avatar
utz
Old Nov 4, 2008 | 05:36 PM
stewy1200c's Avatar
stewy1200c
I've heard a lot of talk about Dana low bars on a sporty, A friend of mine has a Low Rider and I like the bar's on her bike. I would like to see them on a sporty. Does anyone have them on there bike now? If so how about a couple of pictures.
Old Nov 4, 2008 | 07:38 PM
Kski's Avatar
Kski
I agree. Good closeups too.
Old Nov 17, 2008 | 09:08 AM
Kanzig's Avatar
Kanzig
I have the dyna low rider handlebars on my 2006 883 Custom. I'll post some pictures shortly. One of the nice things was the handlebar swap didnt require any wire changes, the brakeline P-clamps were loosened and the line shifted up a couple inches but other than that everything was left alone. I think these are probably the widest bars you can put on before you truly would need to change out some cables.
Pics to follow.
