Grips ?
Old Nov 2, 2008 | 01:16 AM
FunkyFungus's Avatar
FunkyFungus
Default Grips ?
Soon I'll replacing the stock bars with ones from a 1200L. I've ridden a similar XL50 with them and really like the comfort. While I'm at it, I thought I'd ask you guys your opinions on grips. I'm a relatively new rider, but my wrists get a little numb with my current setup, (bone stock). I've seen a lot of the nostalgia grips on Nightsters and they feel pretty good. Should there be a certain brand / set I should consider?
Thanks, as always,
fF
Old Nov 2, 2008 | 03:32 AM
BigBen's Avatar
BigBen
If your wrists are numb, it probably isn't the grips. My guess is it is the bars. Your wrists should not be at an angle when riding. There should be a straight line from your elbo to your nuckles. You may need to change your riding style, rotate your levers, or change/rotate your bars.
Old Nov 2, 2008 | 07:59 AM
vet767's Avatar
vet767
When I changed bars I put the hd nostalgia grips on HD 56275-96B They are about 60.00 Look good feel great
Old Nov 2, 2008 | 08:07 AM
Bacon_Grease's Avatar
Bacon_Grease
+1 on adjusting the bars first. You may not even need new bars, simply adjust them until your wrists are straight.
Regarding handgrips, I like the Kurykan ISO-grips. They have a fair amount of weight to them and very good vibration dampening. Also, they're longer and larger in diameter than the puny ones HD gave you. I like to put some extra weights in the end of them to further dampen vibration.
Old Nov 2, 2008 | 11:14 AM
HDXXX's Avatar
HDXXX
I went with the bars from the low and its alot better for me. Take a trip to a dealer with the grips out on display, and see what feels right.
Old Nov 2, 2008 | 12:38 PM
notfried's Avatar
notfried
my hands went numb a few times right after i bought my bike...put on some HD diamond plate grips and still had the same problem...put on a cramp buster/throttle rocker and never got numb again
Old Nov 2, 2008 | 12:52 PM
SHOAT's Avatar
SHOAT
Try the Dyna Low bars - they are similar to the 1200/883L bars but the ends are turned outwards more which keeps your wrists straighter.
Old Nov 2, 2008 | 04:56 PM
Dango's Avatar
Dango
I agree...plus I added a little heat...really nice! (56619-03A)
Old Nov 2, 2008 | 06:03 PM
higg47's Avatar
higg47
+1 Went with these bars and a set of Willie G. grips one size up and it was like riding a different bike.
REW13
Apr 9, 2017 08:02 PM
davey019
2014-2024 Touring Models
Feb 20, 2017 11:00 AM
hog95023
Aug 25, 2011 12:57 PM
SDVmnt
Touring Parts
Jun 14, 2010 10:14 PM
jprior
Jun 19, 2009 05:03 AM
