883 Engine Guard Bolts
Old Mar 23, 2009 | 07:31 AM
Open Mind's Avatar
Open Mind
Originally Posted by luvmy03spt
Did you use the HD brand or aftermarket? Were they really hard to put on? Got a HD set a couple of months ago and have yet to put them on.Back then wasn't sure if I wanted them or not.
Haven't done this on my friends bike yet, but looks pretty simple.
The holes are there and all I need to do it bolt the bars on, start with the bottom to keep the bar from dropping and then bolt in the tops.
Use a little Loc-Tight to keep the bolts from getting loose, as the engine guards are not something you want to remove once on the bike.
Old Mar 23, 2009 | 07:50 AM
cHarley's Avatar
cHarley
Originally Posted by Open Mind
No torque wrench, one that is typically used to take the wheels off a car without the use of hydraulic air.
A torque wrench is hydraulically pressurized internally to give your own hand power an extra boost of power in pressure.
Not really sure how they work but do a darn good job or getting hard to loosen bolts off most things.
I'm not really sure what the wrench you are describing is really called, but even an amateur mechanic knows a Torque Wrench to be a calibrated device used for tightening a bolt, nut or screw to a specific tension, typically specified in Foot or Inch lbs. and it should never be used for loosening anything.
Old Mar 23, 2009 | 08:28 AM
Open Mind's Avatar
Open Mind
Very true under general applications.
Well I have used mine for some really stock on bolts where the air seals were just to tight and my hammer tapping had failed.
Most bolts won't require that much tension to remove your right.
Old Mar 23, 2009 | 08:39 AM
cHarley's Avatar
cHarley
It's your wrench and your money, but that's a good way to wreck the calibration of a torque wrench. I'm not debating your choice, I'm only posting a response as advice to others who may not know any better. A breaker bar would be a much better choice IMO.
Old Mar 23, 2009 | 08:44 AM
xFreebirdx's Avatar
xFreebirdx
Are you talking about a torque multiplier?
Old Mar 23, 2009 | 08:55 AM
Open Mind's Avatar
Open Mind
There are so many tools, so hard to keep them all straight.
Old Mar 23, 2009 | 08:56 AM
Open Mind's Avatar
Open Mind
I just learned something, didn't know a break bar existed previously.
Going back to read more about it now.
Old Mar 23, 2009 | 11:15 AM
jbg's Avatar
jbg
Awesome!
I imagine, smaller bike, smaller bars. Really huge bars would not look good on a Sporty. See my album and let me know if the bars are about the same size on the 883 I ride, or you got something smaller aftermarket.
It looks like I got the same bars as you. Mine are the HD bars. They don't even stick out as far as the foot pegs. But I can see how they'll protect the engin and maybe the pipes when/if the bike gets knocked over. I wasn't sure about putting them on at all, but now that they're on, I like them. And they were REALLY easy to put on (once I got the damn factory bolts out). But the new bolts use a wrench, not a that stupid 5-star tool.
Old Mar 23, 2009 | 12:12 PM
Open Mind's Avatar
Open Mind
Awesome, I will be on the look out for those Torx star bolts when I install this bar on a friends motorcycle soon. The bike I ride alreay had the bars on the frame.
steveMillar
Engine Mechanical Topics
Nov 9, 2018 08:55 AM
nc883
Apr 6, 2012 08:48 AM
pauletich
Dec 18, 2010 06:58 AM
congo_usmc
Aug 4, 2009 07:18 PM
KeithB
Jan 25, 2007 11:05 PM
