Testing a Ign. module. No spark issue.
Old Apr 19, 2009 | 08:47 PM
racedvl's Avatar
racedvl
Default Testing a Ign. module. No spark issue.
Ok, I have no spark on my XL1200C. I have done the simple test on the coil. And it tests out good. I went through the steps in the service manual, so far not finding my no spark situation. But now I'm in the part of the manual where I need some funky adaptors. Is there just a simple way to test the module? I didn't see one in the service manual. I really just don't wanna just throw one at it. Please help........
Old Apr 19, 2009 | 09:32 PM
sportyguy101's Avatar
sportyguy101
Stage IV
hey racedvl, it's pretty simple, what i did was disassembled the deutsche connector at the sensor end and then the posts will be exposed where you can clip some aligators on to it (being careful not to arch the bare posts). Then you will be hands free to take your reading.
Old Apr 19, 2009 | 10:27 PM
racedvl's Avatar
racedvl
But how do I test it? What am I looking for?
Old Apr 19, 2009 | 10:36 PM
128auto's Avatar
128auto
Do you have a test light?
Check the coil for key on power, then check the negative side of the coil while cranking, see if the test light blinks. If it does, the module is ok, it could be something simple. It could also be the crank sensor, do you have any trouble code?
Old Apr 20, 2009 | 05:19 PM
sportyguy101
Stage IV
so, what procedure are you following in the shop manual? I know of a similar problem and my bike is experiencing a lazy spark. she's backfiring crazily. I was told it was the cam sensor, i replaced that and the problem became more pronounced. so now i think it is the ecm, it could also be the voes switch... ive practically replaced the entire ignition system aside from the ecm. there are cheap parts online in ebay.
Old Apr 20, 2009 | 08:49 PM
racedvl's Avatar
racedvl
There was no power on the black and white wire, wich I belive is the postive side of the coil. If I put the light on the neg. side, (pink wire) it lights but does not flash when cranked.
Old Apr 20, 2009 | 09:10 PM
Gpsjr10's Avatar
Gpsjr10
Looking at the service diag. manual... When you turn the key on, does the check engine light come on for about 4 seconds then go off?
Old Apr 20, 2009 | 09:47 PM
racedvl's Avatar
racedvl
Does that work on a older carbed bike?
Old Apr 21, 2009 | 03:03 PM
Gpsjr10's Avatar
Gpsjr10
The manual I have is for an 02... Thought that it might be close to the same set-up, but now I see that is for the 1200S model.
Old Apr 21, 2009 | 03:34 PM
Gpsjr10's Avatar
Gpsjr10
Here is the flow chart from the book for a non-S model. Hope this helps... I can send it to you as a PDF file also if you can't read it.
Attached Thumbnails Testing a Ign. module. No spark issue.-diag.jpg   Testing a Ign. module. No spark issue.-diag1.jpg   Testing a Ign. module. No spark issue.-diag2.jpg   Testing a Ign. module. No spark issue.-diag3.jpg   Testing a Ign. module. No spark issue.-diag4.jpg
