Stage what???
Old May 14, 2009 | 12:25 PM
PHAT A$$'s Avatar
PHAT A$$
Default Stage what???
this may be a stupid question but, I'm going to ask it anyway... What are the diffrent stages for a pre EFI sporty? I see refrences to stage I, II, and so on.
Do the diffrent parts or number of S/E parts go to the "stage" it is or what? Is there a link or post that explains it?
Thanks,
Jason
Old May 14, 2009 | 12:45 PM
iceman336's Avatar
iceman336
Stage 0: Stock
HP=40 for 883, 50 for 1200 (average)
Stage .5 (also known as "The Harley Tax"): Stock plus:
SE Air Cleaner(1)
SE Slip-On Mufflers or equivalent(2)
Rejetting (DynoJet, Yost or just jets)(3)
HP=50 for 883, 60 for factory 1200(4)
Stage 1: Stage.5 plus
883/1200 Conversion for 883s(5,6,7,8)
SE Ignition Module or adjustable one(9)
HP=60 for 883/1200, 65 for factory 1200
Stage 1.5: Stage 1 plus
Andrews N2 cams (mild)(10)
HP=65 for 883/1200, 70 for factory 1200
Stage 2: Stage 1.5 plus
Andrews N4, N8, or SE bolt-in cams instead of N2(11)
SE S1 Lightning or other bolt-on +/- 10:1 heads(12)
HP=75
Options: 2 into 1 header system, add +/- 7 hp(13)
SE carb (or equivalent), add +/- 3 hp(14)
XR750 (or other) valve springs, no gain(15)
Stage 2.5: Stage 2 plus
Professionally ported 10:1 or higher heads
Matching (to head) domed pistons(16)
XR750 valve springs or SE cam kit(15,17)
2 into 1 header system(13)
SE,S&S Super E, or Mikuni HSR42 carb(14)
HP=90+
Options: big valves (big twin size), add +/- 5 hp(18)
Stage 3: Stage 2.5 plus: (or
Big-bore cylinders and pistons and/or
Stroker kit and/or
Nitrous injection and/or
Supercharging
HP=?
Options: many
http://www.sportster.org/tech/basic-...age-list.shtml
Old May 14, 2009 | 01:13 PM
Krakanator's Avatar
Krakanator
I always thought that a stage I was new exhaust, a high-flow air cleaner setup, and either the rejet(carb) or the addition of a power commander (EFI). The concept of a "Stage .5" is new to me (I realize you did not come up with these, just pointing out). Personally I don't see why an 883 needs a 1200 conversion to be a stage I. And is an ignition module really going to do anything for a motor that is full of stock guts??
Old May 14, 2009 | 01:22 PM
iceman336's Avatar
iceman336
Everyone seems to have a slightly different view on what constitutes a Stage. For example, the following website is classifying this as a Stage 2 even without cams or an upgraded ignition module...but it does give me ideas ;-)
http://www.nightrider.com/biketech/e...0840_dreed.htm
Old May 14, 2009 | 01:48 PM
SHOAT's Avatar
SHOAT
According to the graph the Buell heads don't increase power untill after 4300 rpm. I don't know that I've have ever had my bike above 4300rpm.?
Old May 14, 2009 | 02:18 PM
cdaxj's Avatar
cdaxj
Most people consider that stage one (pc, a/c, pipes), although some/many would add the ignition to fully complete the stage one. that's my understanding.
Old May 14, 2009 | 02:19 PM
cdaxj's Avatar
cdaxj
btw, not a stupid question as there is no clear cut answer...
Old May 14, 2009 | 04:22 PM
PHAT A$$'s Avatar
PHAT A$$
Originally Posted by iceman336
Stage 0: Stock
SE Air Cleaner(1)
HP=75
HP=90+
Stroker kit and/or
Supercharging
HP=?
Options: many
Thanks for the low down iceman... I guess i coulda just googled it
I guess I'm at about a stage .25! lol got pipes and air cleaner, maybe once I jet the carb I can be like a .5! Thanks again for the info.
Old May 14, 2009 | 04:31 PM
killer scott's Avatar
killer scott
I bet ya have... The "redline" is like 6000. 4300 should be pretty easy to come to, unless you take it really easy. Plus if you are the kind of guy that is going to instal Buell heads, then you are the kind of guy that gets well above 4300 RPM.
Edit: I have never ridden a 1200 though, so IDK... Can't immagine it would be that different.
Old May 14, 2009 | 04:45 PM
Boo67's Avatar
Boo67
I'm glad to see the question asked and answered. I've been meaning to ask that myself.
