havin' trans problems
Old Jun 15, 2009 | 11:32 AM
notfried's Avatar
notfried
Default havin' trans problems
i started a thread in the trans/primary section,but i know that there's some experts here and was looking for help from anyone who may have come into this problem before.
here's a link to my thread.
thanks all
https://www.hdforums.com/forum/prima...ml#post5140050
Old Jun 16, 2009 | 03:38 AM
Bentwrench's Avatar
Bentwrench
Default Noisy Trans
I mentioned what I thought it might be; possibly the shifter pawl spring broke and is down in the transmission.
But whatever you find, I'd sure appreciate knowing the result.
Thanks.
Old Jun 16, 2009 | 06:49 AM
notfried's Avatar
notfried
i'll probably open it up this weekend and will get back to you.
Old Jun 16, 2009 | 06:08 PM
bmxatv's Avatar
bmxatv
Thanks.
i think the idea bentwrench had about draining the primary fluid over a magnet was perfect.
Old Jun 16, 2009 | 06:49 PM
woodworking1's Avatar
woodworking1
I recently had a tranny prob as well. It turns out that 2 of the shift drum pins (??? I know) backed out a little and were causing the detent plate to ride a little crooked. This was allowing the "dogs" on some gears to hit a little when the bike was either leaning to the right or under a heavier RPM. (I guess centrifugal (sp) force was causing it to slide over a bit.) I made some calls and got 1 of 2 detent plates in the state! way faster than my indy would have gotten it. I'm glad dealers are open on Sunday's around here. After all that it, was a $3.99 part that cost me about $1000 and a month to find.
Old Jun 17, 2009 | 02:54 AM
Bentwrench's Avatar
Bentwrench
Default Shift Drum Pins
I'm going to tear into mine this winter for what I think is a bent shift fork. It takes a "hard" shift to consistently get into 3rd. A soft shift and I can in between 2nd and 3rd.
The mention of the shifting drum pins backing out causing damage to the detent plate gives me a heads up that I need to take a close look at them.
Thanks for that input.
Old Jun 17, 2009 | 07:05 AM
notfried's Avatar
notfried
for a couple rides before this happened i kept shifting into false gears...ya know,shifting from 3rd to 4th and when it clicks in gear(or so i thought) it would be in between gears like i was in neutral
InthewindMN
Jul 28, 2017 01:05 PM
DinoM
Jul 15, 2015 09:53 PM
paul s
Oil Archive (no new posts)
May 2, 2009 09:52 AM
Cohiba_Joe
Mar 29, 2009 06:33 PM
danzio
Jul 3, 2007 09:46 PM
