Tachometer
Old May 17, 2006 | 11:36 PM
NikoNY's Avatar
NikoNY
Default Tachometer
Does anyone ever wish they had a tach (for those of us without one)? What's the best/easiest/inexpensive way of getting one installed? Would it be worth it or do we just play it by ear?
Old May 17, 2006 | 11:44 PM
PoleCat's Avatar
PoleCat
Default RE: Tachometer
I rode without one for six years on my last bike.
I never thought I needed one. Then I got my Street Glide (with a tach) and now I can't imagine riding without it.
I'd say order one and have it installed. It'll pay for itself in no time.
Old May 17, 2006 | 11:56 PM
bensonjv's Avatar
bensonjv
It can get expensive quick. You'll have to decide how much its worth to you.
Old May 18, 2006 | 12:02 AM
NikoNY's Avatar
NikoNY
Do I need to worry about over-revving or does a limiter kick in before harm is done? Not that I abuse the bike, but just don't want to worry about it.
Old May 18, 2006 | 12:24 AM
locnkey's Avatar
locnkey
I have an o5 Sportster and an 05 bagger, I use my tach all the time on my bagger. I cant understand why any company would build a bike without a tach!
Old May 18, 2006 | 12:59 AM
NYSportster's Avatar
NYSportster
Hey Niko, what part of NY are you from? I'm in Brooklyn. If you're in the city, we should ride.
Old May 18, 2006 | 01:38 AM
Rynb15's Avatar
Rynb15
if anyone has done it how hard is it? I would like to know as well.
Old May 18, 2006 | 01:27 PM
naholos's Avatar
naholos
1st Gear
I just recently installed one on my 06 Sportster. I used the tach kit from Harley(67182-04). It was super easy. I got the tach kit from Zanotti and it came with a little instruction sheet. All I had to do was unhook the Speedometer and mount. Then just replace with the included mount and plug up the new wiring that came. The hardest part was getting the new wire to plug back up. Very tight for my big hands.
Old May 18, 2006 | 02:00 PM
bensonjv's Avatar
bensonjv
You're good as long as you don't have an 04-06 Custom. If you do, all the easy ways to do this are not available due to the speedo housing being part of the riser top.
You can change your riser but then you are adding more expense to it. To make matters more complicated, those risers hide wiring harnesses and connectors in there. Go with a different riser and you lose you hiding spot for that stuff.
For now anyway.......Give them a bit of time and surely they will come up with a happy-glad, nice, clean add-on kit to put a tach on a Custom.
Old May 18, 2006 | 02:40 PM
Nav's Avatar
Nav
They already have come up with all of the parts needed to add a tach to an 04 or newer custom. The cost is a little over $300 for the tach, the mount and the tach housing. I don't know how easy or diffficult it is to install, and I'm not sure if I want to spend $300 to find out.
