starting to backfire when cold
Old Jul 29, 2009 | 11:43 AM
iceman336's Avatar
iceman336
Default starting to backfire when cold
This just started happening last week and I am looking for suggestions on where to start troubleshooting.
The bike is an '06 1200C. When I am taking off for work in the morning, I fire her up and let her warm while I am pulling on my gear with the enricher out - approximately 2 -3 minutes. When I take off, I take it easy and push the enricher in. She doesn't start backfiring until I start throttling up through the gears - sounds like a carb pop. Once she's good and warm, no more issues.
I changed out the plugs about a month ago and run Porker Switchblades with a full Stage 1 and Andrews 515 cams. I haven't pulled the new plugs yet but will be doing that today.
Any suggestions on what to look for in trying to diagnose this issue?
Old Jul 29, 2009 | 11:53 AM
Sick1200's Avatar
Sick1200
Sounds like you're leaving the choke out too long. You should only have it out long enough that she can stay running without it, 20-30 sec. If she starts to cut out after you push it in just give her 1/8 throttle to stay running for a few seconds, let her finish warming up at an idle.
NBryant
Apr 1, 2012 07:36 AM
MGN54
Nov 7, 2010 07:00 AM
eazyrider
Sep 5, 2008 08:52 AM
hull
Jun 27, 2007 09:30 AM
TestFlyer
May 7, 2007 10:59 PM
