Need Help installing Primary Cover
Old Aug 25, 2009 | 02:31 PM
madmarti's Avatar
madmarti
Most of the cover like that have a slit for the clutch cable to slide into so you dont have to remove it.
Old Aug 25, 2009 | 05:18 PM
mikeburgess's Avatar
mikeburgess
No this one has a hole for the clutch cable it's not slotted so i need to release all the tension in the clutch to be able to remove it though the Primary cover to add the chrome cover
Old Aug 25, 2009 | 06:08 PM
SportyPig's Avatar
SportyPig
Just put it on a jack, or get somebody to hold it upright for the hour or so the derby cover will be off, you'll be fine.
Old Aug 26, 2009 | 12:54 AM
oinker02's Avatar
oinker02
Jesus!..........So many bad answers!
First of all, he is installing a chrome primary cover overlay, not a derby cover....Secondly even if he was removing the derby, no oil will leak out while on the jiffy stand unless it is overfilled to start with.
Original Poster, you WILL need to remove the clutch cable to install the chrome overlay. To do that, you must first drain the oil from the primary AND pull the derby cover.....Then you must readjust the clutch cable and clutch release ball ramp assembly.....Look, if you have never done it, it's really a good idea to let someone else do it while you watch.
Death.Proof
Feb 19, 2014 12:30 PM
Joe What
May 23, 2012 05:34 PM
gwolke
Shovelhead
May 17, 2012 11:22 AM
Drdriller
Jun 1, 2011 06:08 PM
fisherdude
Apr 5, 2005 10:33 AM
