fuel pump light
Old Oct 9, 2009 | 03:31 PM
roaddog01's Avatar
roaddog01
Stage III
Default fuel pump light
The fuel pump light on my wife's 08 nightster stays on and the fuel pump doesn't seem to work. I have checked the fuse and it's good. The bike won't start. I will crank but not fire. Is it the fuel pump itself or another fuse or broke wire somewhere. Any help is appreciated
Old Oct 9, 2009 | 03:42 PM
3rdgear's Avatar
3rdgear
I would suggest calling the dealer if its under warranty before you do anything yourself.. but in the case that its not.. buy a book if you dont have one... and then you need to determine if its an issue with gas, air or spark...
Old Oct 9, 2009 | 03:58 PM
HOTLAP's Avatar
HOTLAP
You say the "fuel pump light", I assume you are refering to the "low fuel light", I know it's a dumb question but...do you have gas???
Old Oct 9, 2009 | 04:05 PM
3rdgear's Avatar
3rdgear
DO YOU HAVE GAS... LOL.... Actually its a good question..
sorry had a long day at work today..
Old Oct 9, 2009 | 04:08 PM
HOTLAP's Avatar
HOTLAP
Yeah maybe I didn't word that just right
Old Oct 9, 2009 | 04:15 PM
3rdgear's Avatar
3rdgear
LOL.. sorry.. but I had to..
but no seriously.,. "Check your fuel level" next chance you get..
Old Oct 9, 2009 | 07:38 PM
1200efi's Avatar
1200efi
Smile
Really that would have been my first question also, do you have fuel in the tank. The fuel pump can't pump air. Ride safe.
Old Oct 9, 2009 | 08:37 PM
Blackcherry Low's Avatar
Blackcherry Low
Well assuming that you have fuel in the tank, either the fuel pump is toast or the "System" relay has gone bad. I would suspect the relay, these are know to be problematic. There are two relays on the fuse block and they are identical. One is the "Starter" relay and the other is the "System" relay. You can swap them to see if your fuel pump comes back to life.
If you want to you can push start it from there if you need to get it going. When mine failed, I swapped the relays and the fuel pump came to life and the bad relay even worked a few times to engage the starter.
It could be corrosion in the fuse block also but you would probably have notice this when you were checking fuses.
Just some things to check, hope you get it going soon.
gusotto
General Topics/Tech Tips
Nov 7, 2016 04:25 PM
JonnyB
May 22, 2010 10:03 AM
florit
Apr 18, 2010 07:39 AM
fastolds
Sep 5, 2007 06:46 PM
fastolds
Jun 10, 2007 09:27 PM
