front spring replacement
Old Nov 11, 2009 | 03:48 AM
Billie's Avatar
Billie
Question front spring replacement
Once I have my front forks removed from the triple tree will I have to take them apart to replace the springs or is it just the removal of the spring and spacer? Appreciate you input fellas.
Old Nov 11, 2009 | 04:45 AM
mreed's Avatar
mreed
You don't have to remove the forks to change the springs. Just jack it up, loosen the tree clamps at the top & remove the top tube nut then pull em out (if your bars don't get in the way).
Old Nov 11, 2009 | 06:35 AM
1200efi's Avatar
1200efi
Talking
Be very careful they ARE under pressure. (spring pressure not oil) Ride safe.
Old Nov 11, 2009 | 06:45 AM
Ramboamt's Avatar
Ramboamt
You will have to jack up the bike to remove all of the weight from the front wheel assy. Then carefully remove the top threaded cap from the top of the fork tube, being very careful as the spring is under compression and it will want to pop out. I just pressed down on the cap with my hand while removing it with the wrench. The instructions that come with your new springs should walk you through the change.
Old Nov 11, 2009 | 06:53 AM
SportyPig's Avatar
SportyPig
You're going to need a fork nut socket to open that up.
Old Nov 11, 2009 | 09:47 AM
HarleyScuba's Avatar
HarleyScuba
Sportypig is suggesting one of these:
Notice the o-ring to prevent scratches and the rounded corners to help prevent cracking the chrome. It's a 1 3/8" socket that's shallow to allow working under your mounted handlebars. I think mine is from Motion Pro ("MP 08-0139" stamped on side) available through Denis Kirk, Drag Specialties, etc.
BigDogIdaho
Feb 12, 2015 07:32 PM
MyClassic09
Oct 17, 2013 06:50 PM
mrtom
Shovelhead
May 24, 2013 08:10 PM
RANGER73
Oct 13, 2012 08:04 PM
DavidStiebel
Oct 1, 2010 07:22 PM
