Drop In Spring Kit
Old Feb 12, 2015 | 10:43 AM
BigDogIdaho's Avatar
BigDogIdaho
Default Drop In Spring Kit
I was looking for any bit of advice I can get on installing Progressive Fork springs on my 11 Street Bob. I was going to tear them down to replace seals but it appears I may not have to do this. Which should save me a bit of money.
Everything looks pretty straight forward, but I would like to make sure.
Jack up bike and remove bars to access fork caps.
Loosen top pinch bolts and remove cap (which should be under tension).
Remove old crap and drop in new stuff.
When I cut spacer where should it sit?
Does anyone know how much below top of forks the oil level should be?
Thanks all in advance!
Old Feb 12, 2015 | 11:10 AM
robbyville's Avatar
robbyville
It is pretty straight forward and you have it basically bang on. As for cutting the spacer and where it should sit... If you're not using preload adjusters your best bet is to measure the difference between your stock shocks and the new springs and cut the spacer by whatever the difference is. Then you may need to cut a little more spacer based upon your desired sag setting. If you are adding preload adjusters then you can cut the spacer a little more making the top cap re-install easier.
As for the oil level, remember to set this with the springs and washers out and with the fork tubes compressed, if you don't have the measuring device then you can make your own. Do you have your shop manual? The level should be in there, I know that my manual had a setting that is different from your model year.
It's a pretty simple task, couple of tips, cover your fork caps with tape or a thin shop towel to prevent marring, don't put your face above them, they'll still pop right out. It's obviously easier to compress the forks with the front wheel and fender off, adds maybe 15 minutes of time to the job. If you're changing oil completely easiest is to remove the fork tubes (unless you have forks with drains).
One last thing, you don't need to remove the bars, if you have your mini apes with short risers on you won't be able to get a socket onto the top caps but you can use a regular wrench (35mm I believe). I did not take my bars off
Have fun!
Old Feb 12, 2015 | 02:51 PM
BigDogIdaho
Have fun!
First thing...thanks Robby!!
No adjusters will be installed. Just the Progressive heavy duty drop in kit.
I don't have a shop manual, that is one of the things on my list of future purchases. I won't be changing the oil.
If I don't adjust the oil level and just leave what's in there in there, do you think that would be okay? I am under the impression that the oil level is not a really precise measurement. I could be wrong here of course.
I do have the stock mini apes on there, but there really isn't any risers, so I'm guessing I will have to pop the bars loose to slide them out of the way. At least that's not too big of a deal.
I'll wrap a paper towel over the cap. The socket I have coming has the o ring in it but can't hurt to make extra sure. I'll try to keep my face out of range....I need all the help I can get in the looks department! LOL
Old Feb 12, 2015 | 03:27 PM
robbyville's Avatar
robbyville
You wont need to pull the bars if you use an open wrench, BUT if you're not planning to remove the fork tubes it may make the work easier to have the bars off when fishing/putting in the new springs and then when putting the caps back on.
For the fork oil, it's kind of important that they both be the same and that they're not overfilled. Plus you want to measure with the forks compressed and springs out so if you're keeping the front wheel on during the process you're going to need to lower the jack and get the wheel on the ground to compress the forks (or place something underneath to get them down).
I believe for your year it's around 110mm measured from the top with springs and washer out, forks compressed. Assuming that the new springs are longer than the stock ones there will be more displacement so you'll remove a little oil. Lots of home remedies to make your own measurement and removal tool. Here is an easy one, go to post 17 for pic.
https://www.hdforums.com/forum/dyna-...-i-hope-2.html
Remember to torque those pinch bolts to the right spec, I can look mine up for you tonight if you like or I'm sure google search can come up with it.
Old Feb 12, 2015 | 03:28 PM
DrewNJ's Avatar
DrewNJ
The Progressive drop in kit I installed on my fat Bob had the spacers in the kit. I didn't cut them and it worked out great for me with right at 1" of sag.
Progressive recommends 150mm air space with the forks compressed and no spring/washers installed for the 49mm forks. However, they also say no less than 130mm and no more than 250mm gap so its a pretty broad range for sure.
Since my bike only had 1000 miles on it I siphoned all the oil out with a vacuum oil extractor and replaced with 15wt.
I cut down an aluminum tube to 150mm with a plastic cap on the top. Drilled a hole and ran the oil extractor down into the tube. Filled each fork with oil, worked out all the air, and used the extractor with my home built tube/depth gauge to siphon to the correct level on each side.
Old Feb 12, 2015 | 03:36 PM
robbyville's Avatar
robbyville
Progressive recommends 150mm air space with the forks compressed and no spring/washers installed. However, they also say no less than 130mm and no more than 250mm gap so its a pretty broad range for sure.
Big difference between manual specs and Progressive's suggestion, FWIW this was the same with my changes (springs and intiminators), I did not use the shop manual but went with what most felt best.
Old Feb 12, 2015 | 03:56 PM
DrewNJ's Avatar
DrewNJ
I'm thinking the 150mm vs 110mm might have to do with the spring itself. The OEM spring is smaller so it takes up less volume when installed. Just a guess anyway...lol
Old Feb 12, 2015 | 05:57 PM
robbyville's Avatar
robbyville
True!
Old Feb 12, 2015 | 07:32 PM
BigDogIdaho
Does make sense....
Thanks for all the help on this, I do appreciate it!
Simplespeed
Sep 28, 2016 05:31 AM
mrtom
Shovelhead
May 24, 2013 08:10 PM
ynots
Aug 18, 2011 12:00 AM
151fire
Jul 9, 2010 07:40 AM
bensonjv
Nov 21, 2007 12:56 AM
