Handle bar knurling
Old Feb 6, 2010 | 01:49 AM
blackyck's Avatar
blackyck
Default Handle bar knurling
Putting on some new bars that dont have any knurling. Is there a way to add some myself or an easy DIY technique?
Any advice?
Old Feb 6, 2010 | 07:18 AM
drum412's Avatar
drum412
I put knurles on a set of bars using a 18" channel lock pliers that had nice new sharp teeth. Also have a buddy who did the same buy just clamping it hard in a bench vise that had nice sharp gripping plates.
Old Feb 6, 2010 | 03:34 PM
bmxatv's Avatar
bmxatv
2 very good ideas. you can also hot them with a hammer and punch. may i ask how tall the bars are? i have 14" nash apes w/ no knurling and they don't budge. you should be fine with smaller bars.
Old Feb 7, 2010 | 12:53 AM
blackyck's Avatar
blackyck
ah sweet. They are only 7" rise. Biltwell Friscos.
I am not going to worry about it.
Thanks
Old Feb 7, 2010 | 05:11 AM
oinker02's Avatar
oinker02
Thanks
"What, me worry?"
Hey, it they end up spinning in the riser clamps, just wrap 2 strips of drywall sanding cloth where they mount in the risers....you will think they are welded.
Hardware store/paint store/Lowes/Home Depot has it. "Drywall sanding cloth", NOT sandpaper! http://www.amazon.com/3M-9094DCNA-Dr.../dp/B00004Z4CO
Old Feb 7, 2010 | 12:35 PM
fatguy-littlebike's Avatar
fatguy-littlebike
Originally Posted by oinker02
"What, me worry?"
good idea, ive been watching this thread for ideas. i installed licks 10 inch z-bars on my iron and they're pretty solid but i can still move them... could be bad in a quick stop
Old Feb 7, 2010 | 12:52 PM
oinker02's Avatar
oinker02
Been there-done that several times. I've installed tall bars on many scoots including two of my present bikes....The drywall sanding cloth fixed them all cheap and easy.
Old Feb 7, 2010 | 04:21 PM
midnight2005's Avatar
midnight2005
I didnt have any sanding cloth so i used emery cloth and folded it so the sand hits both sides. worked great.
ps. the reason I did this is because I hit a bad bump in the road wich caused the bars to move. after inserting the cloth I got no movement.
Old Feb 7, 2010 | 04:39 PM
bmxatv's Avatar
bmxatv
i'm pretty sure the drywall cloth is emory cloth. tighten them down man, they shouldn't move.
Old Feb 7, 2010 | 04:46 PM
blackyck's Avatar
blackyck
thanks for the tips all! They are on and solid, but I am waiting for my turn sig relocators. If i need to take the top clamp off for some re-organizing, i am going to use oinkers idea.
