miss. backfire, sputtering
Old Feb 25, 2010 | 02:35 AM
wayne72472's Avatar
wayne72472
Default miss. backfire, sputtering
my 16 yr old got his first harley 883 03 hugger the bike been sitting up for a few months when he starts to take off sometimes it will carb fart he been rideing it to school and back home about 2 miles each way he drained out the old gas, changed the oil, cleaned air filter, new plugs, put in a can of sea fome its not doing it as much now but will still carb fart when he trys to give it gas sometimes it will do it about 2 times if you let it sit and idle for about 3 minutes not as bad as it was. the carb hasnt had any work on it and the motor is stock does have pipes on it the bike was running great i knew the bike before it sit up what do you guys think i should do next
Old Feb 25, 2010 | 03:29 AM
traitor's Avatar
traitor
you could have a look at the inlet manifold rubbers could be pinched and sucking in air.
Old Feb 25, 2010 | 06:55 AM
oldncrzy's Avatar
oldncrzy
welcome to the world of Sportster.
Old Feb 25, 2010 | 07:38 AM
chester1957's Avatar
chester1957
Seafoam might take awhile, first guess would be the idle circuit is gummed up. Second would be to check for intake leaks. Good luck.
Old Feb 25, 2010 | 08:25 AM
Zimbob's Avatar
Zimbob
Like said above, Seafoam will take a little time. Run a tank with it, then a tank without for about 3 tanks each, this should help clean out the carb. Ckeck the gaskets on the intake also. Could also just take a tweek of the low idle screw. You might want to get him a shop manual, worth it weight in gold.
Old Feb 25, 2010 | 09:03 AM
notfried's Avatar
notfried
i'd check to make sure the carb doesn't leak air somewhere,then check the untake...if it's still doing it then i'd pull off the points cover and see if the cam sensor is melted a little
Old Feb 25, 2010 | 09:52 AM
docrobinson's Avatar
docrobinson
it may also be a misfire from being slightly lean. Partially cloged slo jet or one that is just too small. Have had alot of success with changing from stock 42 to a 45
Old Feb 25, 2010 | 09:59 AM
agm1563's Avatar
agm1563
mine was doing the same thing, but I had a bad intake seal. My bike would back fire through the intake, sometimes so bad it would choke it out.
Old Feb 25, 2010 | 07:16 PM
wayne72472's Avatar
wayne72472
thanks guys the boy came in yesterday and told me that the school's head dog said he couldnt ride his m/c anymore on school ground because he is in the 9th grade. what crock of chit he has tags, a dl, insurace, AND A SCHOOL PARKING PERMIT which was given to him by the Principal himself in aug 09 and has been riding everyday! checked the so called
"school rule book" which states he has met all requirements They just change it yesterday!
sorry for the rant by the way, the boy said the bike is running much better now like something "opened up" thanks for the help
Old Feb 26, 2010 | 09:24 AM
fixedmlc's Avatar
fixedmlc
So the school changed the rules and said specifically no more motorcycles allowed? On what grounds did they change the rules? Did somebody ride a motorcycle through the hallways?
