01 Tail lights
Old Mar 11, 2010 | 09:56 PM
lilbruce's Avatar
lilbruce
Default 01 Tail lights
I have a problem with my tail lights dropping down or going straight up. They are loose and I have tried to do anything and tried to figure out how to tighten them down where they dont wobble... How can I fix this?
Old Mar 11, 2010 | 11:10 PM
freekdawg1200's Avatar
freekdawg1200
Your talking about the turn signal stalks,right?My right side turn signal stalk would always vibrate loose.I would just stick a 1/2" wrench up the inside of the fender and tighten it up,but it would soon loosen up again.Not as bad as yours but it was still loose.Last year I had to rewire the entire rear end of my bike because I bottomed out and tore up all the wires that run along the rear fender.When I took eveything apart,I realized the chrome fender strut cover was cracked and wore out where the turn signal bolt goes through.I got a new strut cover and rewired everything.I used a lock washer and some Loctite on the signal bolt when I put it back together.Hasn't come loose since.
Old Mar 11, 2010 | 11:16 PM
lilbruce's Avatar
lilbruce
Yea man that is just what mine did, I didnt know if it was a place to tighten up in the fender or not, thanks for the help... I will have to check that out for sure tomorrow morning before I go for a little ride. I was looking at getting new smaller lights but I am just going to keep the ones I have and tint the lens... Thanks again!
Old Mar 11, 2010 | 11:30 PM
freekdawg1200
You might get lucky and just have to snug the nut up a bit.The bolt runs through the signal stalk and fender.You'll see a nut on the inner fender.It should be a 1/2".Snug it up and you should be good to go!
Old Mar 12, 2010 | 03:14 PM
lilbruce's Avatar
lilbruce
Thank you man I will give that a try, I forgot all about it this morning when I washed the bike
Old Mar 12, 2010 | 03:33 PM
veritas.archangel's Avatar
veritas.archangel
I went with chrome versions of these:
http://www.motosport.com/motorcycle/...talogId=100922
Real small, but bright as heck. And an excellent price.
Old Mar 12, 2010 | 03:38 PM
lilbruce's Avatar
lilbruce
^ Man yea those things are cheap! Nice looking too
Old Mar 12, 2010 | 03:41 PM
veritas.archangel
Look really good on the bike, too. I was amazed at how bright they are.
Old Mar 12, 2010 | 09:01 PM
lilbruce's Avatar
lilbruce
I bet there are bright, they looked like they could thro some light!
colo1032
Jun 9, 2017 12:27 AM
jill.b.danger
General Topics/Tech Tips
Sep 12, 2012 10:08 AM
teabone
Nov 3, 2009 12:36 PM
ricks
Apr 12, 2008 04:00 PM
cam it!
May 24, 2006 08:48 AM
