Dumb oil changing question...
Old Mar 16, 2010 | 12:58 PM
  #41
badger1984's Avatar
badger1984
Originally Posted by SportyPig
Myself, and many other members here with a lot more knowledge about the molecular structure of oils run Mobil-1 gear oil 75w90 in the tranny. One quart. Just pull the primary chain inspection cover and pour in the oil. No need to remove the derby cover.
You can use any regular synthetic motor oil. I just think it makes since to run motor oil in the motor, and gear oil in the tranny. That is also HD's current recommendation.
This is exactly what I was questioning: I took the sporty in for 15k service and they used the synthetic oil in both the engine AND the primary at the dealership. Their reasoning was...only using one type of fluid.
So when I change the primary this next time, should I switch back to gear oil or continue to use 20W50 synthetic - or does it even matter?
Old Mar 16, 2010 | 01:10 PM
  #42
SportyPig's Avatar
SportyPig
The syn oil in the primary seems to be fine. Just from what I have learned, I switched to the gear oil.
Although, I will add the HD syn oil is not a true syn. It's crap.
Old Mar 16, 2010 | 01:15 PM
  #43
SportyPig's Avatar
SportyPig
Originally Posted by brainfrz
Just called dealership- $85 to pull the case and take a look. I think thats well worth the peice of mind.
Take some gear oil with you. They will put HD syn motor oil in there if you don't.
Old Mar 16, 2010 | 01:50 PM
  #44
badger1984's Avatar
badger1984
Well this is nice to know...
I think I will be doing my own services now anyways and will be using a good mobil 1 synthetic.
Old Mar 16, 2010 | 02:21 PM
  #45
brainfrz's Avatar
brainfrz
Well, got service schedule next Tuesday, do you think they'd give me greif for bringing in my own fluids?
Old Mar 16, 2010 | 04:03 PM
  #46
SportyPig's Avatar
SportyPig
They might. Just depends on the dealer. If they do, tell them to kiss your ***. It's your bike. And at this point, you have given them enough information that they wont honor any warranty issues involved with that part of the bike.
Old Mar 16, 2010 | 05:09 PM
  #47
tidefan60's Avatar
tidefan60
I have my 883c for about 2 weeks now, I was told by several harley riders (The really big bikes) that the drain plug was for the engine oil, but fortunately I wanted to be sure myself so I looked here in this forum and found the plastic plug with the hose clamp snapped under the frame. I drained the oil and changed the filter with no problems, now I still have to get some tranny gear oil, is synthetic or regular 75w90 best? I really don't want to pull the primary cover because of the troublesome gasket, so will it be safe to drain all the fluid, and just put a quart back in the inspection cover?
Old Mar 16, 2010 | 05:14 PM
  #48
tidefan60's Avatar
tidefan60
I was wondering Brainfrz, how many times did you change the oil, and if more than once did oil drain from the primary the second time?
Old Mar 16, 2010 | 05:25 PM
  #49
oldncrzy's Avatar
oldncrzy
Been there, done that. But I realized my mistake when I saw the clear oil coming out, like only 1 quart, and the oil in the resevoir hadn't dropped a bit. Running without oil and it still runs....tough bike, I saw a commercial a long time ago that did just that-drained the oil and ran the engine. It actually worked but I wouldn't want to try it. Let us know what the dealer inspection says. GOOD LUCK!
  #50
Faast Ed's Avatar
Faast Ed
I still think this is a joke thread.
C'mon guys, fess up!
