Carb Cleaning?
Old Mar 18, 2010 | 10:17 PM
SportyPig's Avatar
SportyPig
Originally Posted by Driversound
Anybody know how I go about adjusting the primary? Do I need to take the primary cover off or can I adjust it with the little inspection hole?
You will have better responses by starting a new thread for this question.
Old May 6, 2014 | 06:52 PM
Gymcoach11's Avatar
Gymcoach11
Stage I
Hey everyone,
I bought my first harley in March and it's been a great bike so far. It's the 100th anniversary sportster 1200. Last week while riding into work I started having an issue while on the highway. The bike started bucking or hiccuping whenever I would get it up to a higher rpm just before shifting to the next gear. I took it to the local dealership and they said the carb needed cleansing which they did and that whoever had it before I bought it never had it rejetted or dynoed after putting after market pipes on. Ran great home and ran great today when riding it in but towards the end of the ride it started happening again. It not as bad as last week. My question is what could it be and is there an easy fix instead of spending big money at the dealership to get it taken care of
Old May 6, 2014 | 07:19 PM
John Harper's Avatar
John Harper
Originally Posted by Gymcoach11
Hey everyone,
Check your ignition module, sometimes heat causes them to act up. You might have a crankshaft position sensor as well and I've read they are a common source of problems.
Welcome, you probably should post this as a separate topic and you'll get more help.
John
Old May 7, 2014 | 06:16 AM
Spurlee's Avatar
Spurlee
All good advice here but if I was going to the trouble to pull the carburetor and disassemble it I sure wouldn't put 14 year old gaskets and seals back in. Drag Specialties sells rebuild kits (genuine OEM) for a few dollars.
Nice ride for you!
Old May 7, 2014 | 12:41 PM
mrfikser's Avatar
mrfikser
Nice ride for you!
I agree and I would replace the intake gaskets (which may be the real problem)....but to the original poster...I would check the oil levels, pour in some fresh hi test gas with a bit of seafoam and go for a ride (bring your cell) ..you may find all you issues disappear in 10-50 miles...when you start working on a bike with out much history you are sure to cause yourself more misery than is necessary in the long run...
Old May 7, 2014 | 12:45 PM
mrfikser's Avatar
mrfikser
Originally Posted by JosephGarcia
sportsters are the EASIEST bikes to pull the carbs off. two bolts removes the air cleaner, and the carb just pops out.
and there is hundreds of guides on what to do with it once its off.
some tips,
when reassembling, use your finger and spread a thin layer of grease on the float bowl gasket and on the rubber boot that the carb slides into.
while it is prolly the easiest carb to remove it is not quite as easy as you say...there are throttle cables to deal with and the enricher (which will prolly break,as it iscrappy plastics) along with the float bowl hose and a voes hose...
Old May 7, 2014 | 12:52 PM
$eventy2T's Avatar
$eventy2T
remove, clean properly, use proper tools and air comp, reassemble and be done with it.
Old May 7, 2014 | 02:56 PM
xtremeskier97's Avatar
xtremeskier97
Hey everyone,
If you already PAID the stealership to fix the issue (since they said the carb needed to be cleaned and they did it) then I would take it back to them since they didnt fix the issue you paid them to fix.
And the original post is about 4 years old...so I doubt he still needs help LoL. Evidently Gymcoach11 revived a VERY old thread.
Old May 7, 2014 | 05:24 PM
Wildon883R's Avatar
Wildon883R
Originally Posted by jag1886
I doubt the mechanic in a can is going to help much on a 10 years old bike that's been sitting.
I just had to redo the carb on my 2000 last fall for the first time and it doesn't sit.
All you need is a small dip tank of carb cleaner from your local parts store and and disassemble the carb and soak it over night and then wash the parts in HOT water and reassemble it. You don't even need a kit unless you mess something up taking it apart.
Just take your time, there aren't that many parts to that carb.
The manual states explicitly to not soak a CV carb in carb dip. Just saying.
Alveus
Carburetor Related
11
Jan 1, 2017 12:46 PM
traildog
EVO
34
Aug 10, 2014 09:10 PM
HD7585
EVO
Jul 31, 2013 12:27 AM
Ripsher
Carburetor Related
11
Feb 21, 2011 02:23 PM
Canuck HD
Oct 19, 2007 05:15 PM
