Carb Cleaning?
Old Mar 16, 2010 | 03:35 PM
Driversound's Avatar
Driversound
4th Gear
Default Carb Cleaning?
Hey guys, I just recently purchased a 2000 883XL from someone who let it sit for about 2-3 years. The bike only idles with partial choke and will stall if pushed all the way in. I believe the main jet is partially clogged and the carb must be filled with gunk after all that time. I'm completely new to motorcycles and was wondering on how I can go about cleaning the carb? Should I take it out and clean it or would there be an easier way?
Old Mar 16, 2010 | 03:59 PM
SportyPig's Avatar
SportyPig
Try running Seafoam through it first. You can find it at any automotive parts store. White can, with red writing. The stuff is GOOD. Very likely to solve your problems.
Old Mar 16, 2010 | 05:45 PM
Driversound
4th Gear
Thanks for the reply. I was thinking of doing that already first but I never seafoamed a motorcycle before. I used seafoam in all my cars running through vacuum lines. I am assuming using seafoam only as a gas additive?
Old Mar 16, 2010 | 06:24 PM
jag1886's Avatar
jag1886
I doubt the mechanic in a can is going to help much on a 10 years old bike that's been sitting.
I just had to redo the carb on my 2000 last fall for the first time and it doesn't sit.
All you need is a small dip tank of carb cleaner from your local parts store and and disassemble the carb and soak it over night and then wash the parts in HOT water and reassemble it. You don't even need a kit unless you mess something up taking it apart.
Just take your time, there aren't that many parts to that carb.
Old Mar 16, 2010 | 08:39 PM
Mike07FLHTC's Avatar
Mike07FLHTC
I'd pull the carb and clean it like jag said,not that bad of a job.BTW the main jet kicks in at 3/4 up to full throttle it may be clogged but thats not why it doesnt idle.The slow jet may be clogged up.Did you turn the idle screw in ?hows it run when you give it some gas?
Old Mar 17, 2010 | 03:28 AM
Driversound
4th Gear
As far as I know, the setting on it is from factory. The bike is completely stock. It's a 2000 with 5,6xx miles. The bike sat in the garage for years. I think I'm just gonna pull the carb this weekend and clean it. I'm new to motorcycles so I kinda have the newbie jitters about messing with it. Thanks for the advice!
Old Mar 17, 2010 | 05:58 AM
eazyrider's Avatar
eazyrider
I wouldn't worry about it. Pulling the carb is easy. I would also reccomend draining the gas tank if it was left with fuel in it. You may have to flush that as well.
Old Mar 18, 2010 | 07:21 PM
Driversound
4th Gear
Anybody know how I go about adjusting the primary? Do I need to take the primary cover off or can I adjust it with the little inspection hole?
Old Mar 18, 2010 | 07:28 PM
SeeMeDo's Avatar
SeeMeDo
You may want to pick up a service manual before you get beat up to bad. try using the search feature you'll find a lot good threads for all your questions I know I have. Good luck.
Old Mar 18, 2010 | 07:38 PM
JosephGarcia's Avatar
JosephGarcia
sportsters are the EASIEST bikes to pull the carbs off. two bolts removes the air cleaner, and the carb just pops out.
and there is hundreds of guides on what to do with it once its off.
some tips,
when reassembling, use your finger and spread a thin layer of grease on the float bowl gasket and on the rubber boot that the carb slides into.
