Bike won't start
Old Mar 26, 2010 | 05:12 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Default Bike won't start
It's a 2009 Sportster Low, 43 miles on it.
I literally bought it yesterday from an authorized dealer. They had it safety'd and plated.
Pulled her off the lot just fine, had 11 miles at that point. Rode it for about 3 hours yesterday...put about two miles on it this morning. Pulled it in and it sounded perfect.
Went to start it about an hour ago, and it just clicks (fast clicking). All the cables look good as far as I can see. Won't turn over or anything (it tried to once or twice).
I'd call the shop but they're closed. I'm calling tomorrow regardless, because this shouldn't be happening.
Any ideas?
Old Mar 26, 2010 | 05:27 PM
cHarley's Avatar
cHarley
It's most likely a dead battery and you should check that first. Do you have a volt meter? A charger?
Old Mar 26, 2010 | 05:36 PM
Ragnar Danneskjöld
I have none of that here. I guess I'll just have to give them a call.
It only clicks once now, for the record.
Old Mar 26, 2010 | 08:48 PM
Stefan's Avatar
Stefan
Originally Posted by X04D
Went to start it about an hour ago, and it just clicks (fast clicking). Any ideas?
Battery is weak.
The stealership should be able to test the battery. They should not just replace it.
Old Mar 26, 2010 | 08:52 PM
1931jamesw's Avatar
1931jamesw
Dead battery.
Old Mar 28, 2010 | 11:41 AM
Ragnar Danneskjöld
Grabbed a battery tender and hooked it up. Charged for 16-17 hours, then the light turned off on the tender, so I assumed it was good to go. Tried to start it and it turned over, but wouldn't start. Did that a few times, but now it just clicks again.
Hooked it up to my buddies bike and tried to get a jump, still nothing.
Old Mar 28, 2010 | 12:16 PM
1931jamesw's Avatar
1931jamesw
Check your connections. I still think it could be the battery. After charging one a while (17 hrs) they make seem charged breifly but really wont hold a charge and run down quickly again (turning over the motor some). If your connections are good, pull the battery out and take it to any parts dealer and have them do a load test on it or if you have a load tester then you can do one. If the parts place does it for you it should be a free service they offer and not cost you anything....except a new battery.
Old Mar 28, 2010 | 05:00 PM
Grammaton's Avatar
Grammaton
A battery tender will maintain the charge on a full battery. It could take weeks to fully charge a dead battery. You need a battery charger.
Old Mar 28, 2010 | 05:19 PM
Stefan's Avatar
Stefan
Remove the seat & check the voltage (DC) of the battery & when trying to start. I don't recall the minimum required. It is like a car under 10 volts & it won't likely start. Once started get the RPM over 3k & you can watch it charge. As mentioned by somebody else if you then shut down the battery will not likely have gotten charged. Idle will wear out the charge.
Old Mar 28, 2010 | 05:40 PM
BassCatcher's Avatar
BassCatcher
With 43 miles on an 09, it's been sitting way to long. Like everyone has said, it's the battery. Get the dealer to give you a new battery and put that one in.
