i got the risers on ebay, speedo mount from a forum member, lot of guys who did speedo relocations on their nightster have these parts layin around, depending on how complete a kit you can locate you may need extra parts like a back plate, rubber gasket, light pig tail it is LED for 07 and up....couple other misc parts.....
as requested, internal wireing and turn signal relocation are on my to do list, but im pretty lazy......You can use the custom riser but you will need new cables wire extension and extended brake line
It's beautiful! do you happen to have the part number for the bars? those are the ones I want! and...
are those 1" or 2" risers?......
I think I'm going to use the stock speedo housing though....unless there is a reason you can't
i am going to try the frisco bars, they have a 7 inch rise and the chumps are 8. so i am happy to see you did this without changing any cables or wires. but i would also like to know what size riser you used 1 or 2 inch, i was thinking of using a 1 and a half inch with pullback. not sure.
and to v-twinSB i dont think u can use the stock speedo mount off a custom, with that low of a riser, speedo will hit the tank.
