Ignition Switch
Old May 19, 2010 | 10:58 AM
SportyPig's Avatar
SportyPig
Default Ignition Switch
Just wondered if anybody has experience with replacing the ignition switch. Looking for tips and/or pitfalls.
Old May 20, 2010 | 12:49 AM
XLCR4GM's Avatar
XLCR4GM
Hey SportyPig,
I started having problems with the ignition switch on my 1999 XL883 a little while ago so I replaced it. Really, very easy to do, man! Disconnect the battery first and then unbolt the gas tank and remove it. The ignition switch is in the front gas tank mounting bracket. Just one screw to remove to be able to take the ignition switch out of the bracket! I cut the original harness wires very close to the harness and I used the wire crimps to attach the new wires from the new ignition to the original wires on the harness. I used some electrical tape to cover the new splices and the wire crimps and I remounted the ignition back into the gas tank mounting bracket and I replaced the gas tank back onto the frame and re-connected the battery and I fired her up! No problems with the ignition anymore. Give it a shot, you can do it man!
paulswhite
Jul 17, 2015 10:20 PM
Charlie588
Oct 5, 2012 11:12 AM
Reef Rider
Jan 23, 2012 04:18 PM
Purposportcustom
Dec 22, 2009 10:21 AM
skullguy
May 6, 2009 02:59 PM
