Nightster makes a humming noise only backing it up
Old May 19, 2010 | 04:34 PM
nightster062008's Avatar
nightster062008
Stage I
Default Nightster makes a humming noise only backing it up
Does anyone have any idea it could before I go to the dealer waste my money? I was backing into my parking space a soft humming came from the back of my 2008 Nightster.
Old May 19, 2010 | 06:17 PM
snacks63's Avatar
snacks63
its the rear brake pads next time tap the rear brake pedal and see if it quits mine has done it from day 1
Old May 19, 2010 | 06:46 PM
papadop88's Avatar
papadop88
its prob your rear brake. Mine does it too when its nice and warm. Heard alot of people's does. It's just singing to you bro. No worries
Old May 19, 2010 | 09:24 PM
ericb445's Avatar
ericb445
Rear brake
Its normal
Old May 19, 2010 | 10:37 PM
09NightsterVB's Avatar
09NightsterVB
Rear brake. I sprayed some WD-40 (just a little squirt) on the back of the pads. Haven't had it since (2k miles)
Old May 20, 2010 | 11:03 AM
Kenny94945's Avatar
Kenny94945
WD sprayed onto brake pad backing plate.
If it worked OK, yet I thought WD should not be used near pads.
So the WD is lubing the surface between the one caliper puck and pad backing plate?
Or it is lubing the surface between the part of the caliper and the stationary pad?
There is disk brake grease that could be used sparingly on the pad spring, pin, surface of the puck where it contacts the pad and inside part of the caliper where it contacts the non moving pad. This may reduce the harmonic vibration noise when reversing the bike.
Agreed normal sound when reversing...I never hear it when moving the bike forward.
Old May 20, 2010 | 12:26 PM
HOTLAP's Avatar
HOTLAP
It's just a sigh of sadness from your bike cause it knows your going to shut it off.
Old May 20, 2010 | 12:49 PM
XsjadoNightster's Avatar
XsjadoNightster
Well put.. mine does it too
Old May 20, 2010 | 01:21 PM
Doctrey's Avatar
Doctrey
Mine does it, too. But I thought it was just because I'm fat.
Old May 20, 2010 | 01:38 PM
XL50#674's Avatar
XL50#674
My bike does it real bad-it's normal. The pads sit on the rotor and it's the pads dragging on the rotor. As long as the bike is easy to roll there is no issue. All bikes have a brake noise at low speeds. My Z1000 has a nice hiss when rolling it or at very low speeds.
njpersaliano
Apr 18, 2017 02:56 PM
TruIslander
Mar 15, 2013 11:13 PM
Skeet7373
37
Nov 20, 2012 03:06 PM
Louderisbetter
Jul 1, 2012 05:58 PM
aztsm
Mar 16, 2011 04:08 PM
