So, being a tight penny pincher from the west I don't like spending money. Problem is I just bought a 08 nightster and of course it can always be better, and I wanna make it MINE. I want a set of smaller ape hangers and haven't really seen any that are matching the picture in my head, or the price tag niether. So my thinking is that I am gonna build my own. Wondering if anyone has tried to and if you have any tips. What sort of material should a guy use? Will a mig welder do the trick or should a guy get them tig welded? How hard would it be to drill and dimple them for internal wiring? Any help would be great.
And what questions should I be asking? I'm not just some guy doing this out of his basement. I've been welding since I was young young. Living on a farm teaches alot. I have built 4x4 rigs on budget since I was 14, meaning there is alot of fabbing to be done. I also have a friend with a TIG welder, that is alot cheaper than going and paying $60-120/hour shop rate. I have a bender and quite a bit of know how.
get 1inch od tube and get busy. you'll probably have to fab a dimpler. maybe use a piece of 1/4 inch solid stock and a press? theres a knurling tool floating around the internets. or you can use a punch... the knurling tool aint cheap.
tractor supply carries 1" od tube pretty cheap. a lot cheaper than mcmaster carr.
you need DOM tubing, not just some random pipe; that will work the best. Also you can absolutly weld them up with a MIG, thats how i made mine. I didn't dimple or drill my bars for wires so I can't help there but I hope some of that info helps. I can't remember the exact thickness of the DOM tubing...I tried to find it but i don't have it....I think i used some pritty thick stuff just to be safe...something like 1/8"...but with DOM its always in decimals.
1/8" is 0.125. You definitely want to use tube instead of pipe. Tube is structural material and is measured by the outside diameter. Pipe is a transporting vessel and is measured by the inside diameter.
Question. I've been told black iron pipe from home depot is thicker but stronger than dom and a quarter of the price. Anybody tried this? 3/4" or 5/8" id = 1" od I belive.
You can also use aluminum tube but you'll want a larger wall thickness than 0.125.
MIG welding the bars will be plenty but TIG usually looks alot better.
And if you are planning on internal wiring you won't need to dimple the bars.
What would the advantage of using aluminun? I want black bars so there is no advantage there. Sure they will be lighter, but it is a harley, so i dunno if that is a real issue. Also you say I won't need to dimple them for internal wiring? How do you internal wire them then, or is there enough room for wires in the controls?
