Fuel Pump Noise
Old Jul 7, 2010 | 11:27 PM
09NightsterVB's Avatar
09NightsterVB
Default Fuel Pump Noise
2009 Nightster, 7500 miles, every once in a while when I turn it on (not started yet) the fuel pump will let out what can only be described as a "whistle" type of sound. Not sure what this is or what it means. Any ideas?
Old Jul 7, 2010 | 11:43 PM
chevy94ss's Avatar
chevy94ss
Mine does the same thing if its been sitting a while or if its sits outside in the heat. Mine is a loud screaching almost like nails on a chalkboard but in a lower tone. I believe its normal and its just the dry pump trying to suck up fuel and prime the engine. BTW I have 20k miles on my '08 and haven't had any fuel related problems.
Old Jul 8, 2010 | 12:01 AM
Topdogg's Avatar
Topdogg
That is exactly what it is, its the fuel pump priming the engine.
Old Jul 8, 2010 | 10:34 PM
09NightsterVB
It has awlays kinda whirred when it primed eveything, but the whistle is pretty new. Just wanted to check to see if it's anything to be concerned about.
Old Jul 9, 2010 | 02:19 AM
lumberjacker's Avatar
lumberjacker
the wifes started the same thing about a week ago. sounds like a jet spooling up. after it starts it gives a 1 second squeal like its vapor locked. runs fine, dont do it all the time? you're not alone...
Old Jul 9, 2010 | 11:56 AM
tiger_rider's Avatar
tiger_rider
The fuel injectors need to be pressurized before the engine can start.
Old Jul 9, 2010 | 01:54 PM
WVNightster's Avatar
WVNightster
Mine does this from time to time.Like chevy94ss said it only has done it after it has been setting out in the heat.
Old Jul 9, 2010 | 02:04 PM
soft 02's Avatar
soft 02
If you think you have a leaky hose on the fuel pump open the fuel cap and with a flash light (not a lighter) look in the tank for fuel spray when you turn the ignition on and it primes up.
Old Jul 9, 2010 | 05:53 PM
haknslash's Avatar
haknslash
Mine did this crazy spool up sound like turbo spool once. It was after it had been sitting for a week or so without running. It was also VERY low on fuel. As soon as it did it I turned the bike off and scratched my head. Went to turn it on again and no crazy spool sounds, just the normal prime sound. Went to top off the gas tank and it's never done it since. I'm thinking maybe my issue was that it was pretty much on fumes at that low of fuel level and the pump had nothing to prime. Who knows. Knocks on wood but bike runs great and it only did it that one time.
Old Jul 9, 2010 | 07:28 PM
riley249's Avatar
riley249
5th Gear
Default fuel pump noise on 2007 Sportster
In June, while in Nashville, fuel made high pitched noise, after setting out in sun,but did not stop. Went to Boswells HD in Rivergate and they changed the fuel pump. Ok since, had 22,060 miles at that time.
morleyz
Apr 4, 2014 12:21 AM
swillerbob
Sep 24, 2012 06:08 AM
08HSTC
Mar 5, 2010 11:06 AM
CTB
Apr 14, 2008 08:06 PM
davidwideglide06
May 2, 2007 07:09 PM
