Adjusting shocks
Old Jun 19, 2005 | 03:02 PM
aggscott's Avatar
aggscott
6th Gear
Default Adjusting shocks
I just got a 04 sporty 1200R. It didn't come with a manual, and I was just wondering how to adjust the shocks! My wife and I ride alot and it seems like its getting worse than it was about a month ago. It only has about 800 miles on it.
Old Jun 19, 2005 | 04:09 PM
1200c's Avatar
1200c
Default RE: Adjusting shocks
This is what the owners manual says.
"To adjust the rear shock spring preload, turn spring adjusting cam to the desired position with a spanner wrench. When reducing preload, cams should be rotated in opposite direction. A SPANNER WRENCH (Part No. HD-94820-75A) is available from your Harley-Davidson dealer."
On your roadster there will be three preload positions. You put the spanner wrench in the notches and turn until it pops into the right position. On my bike I turn towards me to put it into a higher preload position. I've also been told that if you have some strength, then you can put a towel over it and turn it with your hands. I haven't tried that since the wrench is cheap.
fastdeuce
Apr 29, 2011 12:36 PM
DustMan
Jun 1, 2007 01:08 PM
saracen
Apr 18, 2007 12:17 PM
Mrkicks
Oct 20, 2005 10:23 PM
bogie
Sep 24, 2005 04:08 PM
