'99 883c front caliper question
Old Oct 25, 2010 | 09:00 PM
mreed's Avatar
mreed
Thank you
Old Oct 25, 2010 | 09:23 PM
RandyDowdy's Avatar
RandyDowdy
My 99 883 has a bushing in the bottom, you can see it near the fork. No movement whatsoever.
But, I took my wheel off when I painted the fenders, and now it seems like my rotor is bent. Never been laid down, didn't pry on it, nothing. Just seems to make a funny noise when I am NOT on the brake. Didn't do that before.
Good luck with yours, I say a bushing is missing.
Old Oct 25, 2010 | 10:01 PM
cultfreak's Avatar
cultfreak
Wink
I just went out and messed with it. here goes...
if I hold the caliper flush against the fork and bolt it to spec the inboard pad is far away from the rotor.
if I do not hold it against the fork and bolt it to spec the gap shows back up but the pads align perfect.
I did it both ways with the old pads and the new pads, same results each time.
amount of movement both ways is about the same. I have compared ever piece with the exploded diagram in my HD manual and nothing appears to be missing.
I really need to get another bike so when one is down I can still ride.. then again I would probably never fix the one that is down if I am out riding.
Old Oct 25, 2010 | 10:03 PM
cultfreak's Avatar
cultfreak
did you check and make sure the outboard pad did not come off the spring clip?
this caliper/pad design seems crappy to me. love the way PM does theirs.
Old Oct 30, 2010 | 03:49 PM
RandyDowdy's Avatar
RandyDowdy
No I didn't, but I will. Thank you.
dproto09
Jul 18, 2023 01:31 PM
SDozier
Apr 13, 2017 08:48 PM
wrenchman9
Ironhead
May 13, 2015 07:27 PM
neilpp
Jul 5, 2013 09:05 PM
Muddyape
Wheels/Tires
Dec 23, 2012 11:06 AM
