Upgraded brakes?
Old Sep 21, 2006 | 04:21 PM
OldFenderGuy's Avatar
OldFenderGuy
Default RE: Upgraded brakes?
When I upgraded to a WideGlide front end I was also required to upgrade to a 4-piston front caliber, but I didn't see anything wrong with the 'stock' front brake and 2-piston caliper.
How much braking power do you need?
From what I recall I was able to 'lock up' the front wheel if I wanted, so the braking power was limited to the small tire footprint, not the breaking system. Also, I never experienced any brake fade during normal stop and go traffic.
The only valid reason I can see for replacing or 'upgrading' is if you are racing or doing extreme riding, where you are constantly on and off the brakes and start to experience brake fade.
Old Sep 21, 2006 | 06:28 PM
ronn39's Avatar
ronn39
The only reason for adding that unsprung weight of a second disk/caliper that I can think of is if you must do a lot of downhill racing and your single disk fades on you. Since your right slider doesn't have the mount, you'll have to add that as well. But I can lock up that front wheel with the single (a very carefully controlled test; I really wouldn't want to in a panic!!!!), so I'm not sure the purpose.
Old Sep 21, 2006 | 06:50 PM
FLBikerchick's Avatar
FLBikerchick
All good points. I'll discuss it with my shop. I hadn't really thought about the extra weight from the second disk/caliper, so I think I'll just look into other options. Maybe better pads. Thanks for the info, everyone!
Old Sep 21, 2006 | 10:21 PM
hdxl1200r's Avatar
hdxl1200r
FLBikerchick,
I just took my right front brake off my 2004 Roadster. It was just rebuilt by the Harley Dealership. I have the dual brake line, front disk, and brake caliper. You could get a 19 inch roadster rim or you can drill the hub on the 21 inch wheel and add the disk to it. I have instructions on how to do it. Either way I would sell those parts cheap if you are interested. The only other issue is the master cylinder on the handlebars is larger on a dual brake set up.
To tell you the truth, I removed my right brake and hardly noticed the difference. I have all the stopping power I need with one brake.
Old Sep 21, 2006 | 10:23 PM
hdxl1200r's Avatar
hdxl1200r
Forgot one other thing, you will also need a new right front fork leg. You need the caliper bosses on there to hold the brake.
rauchman
Jun 25, 2023 05:47 AM
LAFO
Apr 20, 2018 11:17 AM
beendad
Jan 2, 2016 06:07 PM
texas ultra
Dec 3, 2012 10:19 PM
roadglider09
Feb 24, 2010 12:41 AM
