Searching for sixth gear
Old Sep 23, 2006 | 11:17 AM
HeliRider's Avatar
HeliRider
Default Searching for sixth gear
Maybe it’s just me but I always seem to be looking for a sixth gear when cruising. Cursing @ 65 mph @ 3100 rpm’s just seems the bike could use a sixth gear. Does anyone else feel the same way?
Also, I posted some pictures of my new KURYAKYN PREMIUM ISO-GRIPS, they are great and I like them a lot.
Two notable items:
1st The grips are made for big hands
2nd You need to be absolutely sure when you install the left hand grip that you have the grip in the position you want because you don’t get a second chance after applying the glue and sliding the grip onto the bar the bold is immediate.
Old Sep 23, 2006 | 11:30 AM
boom215's Avatar
boom215
Default RE: Searching for sixth gear
i feel what your saying. But atter going on a few half decent length trips youll find your bike is happy there.
Old Sep 23, 2006 | 11:48 AM
OldFenderGuy's Avatar
OldFenderGuy
At 3,100 RPM you are just starting to get into the 'peak horsepower and torque' range with both the 883 and 1200 engines.
Harley V-Twin engines love to run in the 3,000 - 3500+ RPM range, non-stop for thousands of miles/hours if needed.
Old Sep 23, 2006 | 12:10 PM
jshall755's Avatar
jshall755
Yes, I also still find myself attempting another upshift just to make sure I'm in 5th.
As far as the grips go, I just installed the same set on my bike. At first I didn't like where the throttle boss ended up even with adjusting it using the screws on the end. I rotated it all the way down, which wasn't quite far enough. Then I tried removing the screws to rotate the slots on the screws like the instructions said, but that put it too low. I ended up adjusting the throttle cables to get the grip rotated down where I wanted the throttle boss to be. I think they should have mentioned that in the instructions as a way to get the boss into that "in between" area.
Old Sep 23, 2006 | 01:15 PM
SportyPig's Avatar
SportyPig
I agree the bike seems happy at that RPM level and speed, but I also find myself trying to click up just one more time.
Old Sep 23, 2006 | 01:17 PM
Garemlin's Avatar
Garemlin
I used to do it all the time with my Sportys. It was even worse with my 91. I kept searching for a fifth.
Old Sep 23, 2006 | 02:36 PM
whaap's Avatar
whaap
I used to have that problem with a metric (VT 1100) but I don't have it with my Sportster. I thought after I bought my 1200 C that I would want to be adding a tach like I did on the VT but for me it's not necessary.
Old Sep 23, 2006 | 02:51 PM
OldFenderGuy
I've done the 'false shift into 6th' from time to time....
Makes 'ya feel like a complete idiot. (Well, I feel that way anyhow)... LoL... [8D]
Old Sep 24, 2006 | 02:41 AM
Tralfaz's Avatar
Tralfaz
Good news for me is that the wind buffeting is so bad when I get above 65 that I really don't need that 6th gear anyway.
I'm still torn on the windshield thing. I know it helps a lot, but I just don't like the look of it. This is the ultimate contest of form over function.
I tried kicking it up to 75 the other day, though, and really the engine felt happy. I was the problem there since it was just downright uncomfortable having to spend more time trying to keep my hands on the grips than enjoying the ride.
Old Sep 24, 2006 | 09:34 AM
CHASE's Avatar
CHASE
Glad I'm not the only one who keeps tryin to shift into a higher gear.
