will these shocks fit ???
Old Dec 12, 2010 | 11:30 AM
fourburgs's Avatar
fourburgs
Question will these shocks fit ???
Will these shocks fit my 2010 1200 custom And keep the ride hieght the same??? Are they a good Replacement shock upgrade ??? Also considered proggressive 412hd in 12 inch lenght also.Any HELP would be greatly appreciated THANKS
fourburgs's Avatar
fourburgs
Sorry Here is the link http://cgi.ebay.com/ebaymotors/CHROM...Q5fAccessories
Old Dec 12, 2010 | 12:13 PM
sexpanther's Avatar
sexpanther
they will fit. i have the black ones on my 2010 sporty. In my opinion, the ride is better than it was but take what you read on the forums with a pinch of salt- they are not miracles.
not sure if 12" is same length as your stock ones though - measure your current shock eye to eye and see what the stock length is
Old Dec 12, 2010 | 12:31 PM
ubiasylum's Avatar
ubiasylum
I think the Customs are 11.5" stock, so those will add 1/2" to your current height.
Old Dec 12, 2010 | 06:33 PM
HDCruzin's Avatar
HDCruzin
Cant really tell from the ebay description who makes them. I put a pair of OEM Street Glide air shocks on my 1200 Custom which are made by Arnott. I think they all say 12" but they are really like 11.75. The installed height was exactly the same as the stock shocks, which on the Custom are already a lowered shock kit. I like the ride performance a lot better than the stock. I put about 30 lbs of air for me and will bump it up to about 40lbs for 2-up. You will need to put spacers and maybe longer bolts cause the shock diameter is bigger and would hit the belt guard. The stock shocks bottomed out with the max preload and didnt take the bumps too smooth.
Old Dec 12, 2010 | 07:01 PM
rnl_1200C's Avatar
rnl_1200C
since shocks are mounted 45 degrees, would the height only be increased 1/4" ?
Old Dec 12, 2010 | 07:28 PM
cHarley's Avatar
cHarley
The stock factory shock on a Custom is 11.75". Given the mount angle of the shock, a 12" shock won't change your ride height more than 3/16". You really won't see any difference in height.
If you're considering going with Progressives, I recommend using the 12.5", as they have a better spring rate which provides a better ride.
Old Dec 12, 2010 | 10:09 PM
hig4s's Avatar
hig4s
Seeing as I am not short, I actually went with 13.5in Progressives, gives the bike a very nice ride.
Old Dec 13, 2010 | 05:43 PM
fourburgs's Avatar
fourburgs
Thanks guys... Went with the 412hd @12.5 and going to put Amsoil Shock Therapy Fork Oil 10wt. up front for now and see what happens.
gant
Sep 29, 2014 12:04 PM
nh-rider
Jul 24, 2013 08:52 PM
rodhotter
Jun 17, 2013 08:59 PM
lmferris
Aug 31, 2011 01:48 PM
ptl203
May 27, 2011 09:47 PM
