Removing Head Gasket
Old Dec 23, 2010 | 06:36 AM
WRAITH's Avatar
WRAITH
The graphite compound left behind, can be easily removed with a plastic knife.
Old Dec 23, 2010 | 10:46 PM
farmerstu's Avatar
farmerstu
Originally Posted by misfitJason
het a die grinder or a dremel too and gently, I mean gently, sand off the remainer and then use a cleaning solvent or gasket prep to clean and prep the area
i know i'm about the 10th reply saying don't do this. don't do this.
and i've said it before. when a poster asked for technical advice what promps **** like that. you don't have a clue. you just like to see your post? or do you get your kicks hoping you'll screw up someone. normally i try hard to be nice but come on if you don't know don't post!
to the op permatex makes a gasket remover spray that combined with the razor blade work good.
JimmieJack
Exhaust System Topics
Feb 7, 2011 08:24 PM
rivercityslim
EVO
Nov 16, 2009 02:50 PM
straydog13
Ironhead
Aug 19, 2008 09:44 AM
iknowyoueazyryder
Ironhead
Feb 18, 2008 05:25 PM
snod
Jan 28, 2008 08:35 PM
