hi there i need some help. my alarm will not stop on my 07 883L every time i turn on the key the alarm is flashing/screaming i changed battery in my fob that didnt help , i took out the master fuse hoping it would reset . it didnt , took out the main battery that didnt help , i didnt take the battery out of the smart siren yet , should i ?? will that reset it ?? i did manage to put it into silent mode so the neighbores wouldnt start complaining . but i need to stop the alarm as the bike wont start while alarm is tripped . i did put a fresh battery in the smart siren a week osr so ago but its been working fine since then until today. im stumped anyone have any suggestions ????? it is still going off as i sit in here typing i can see the turn sigs flashing
If the smart siren senses no power It will go off on Its Internal battery.
Incase some thief cuts power..It will still scream.
If that Internal back up battey goes bad It will go off,,,If still connected to main battery.
Loose power lead or antenna touching frame ?
Disconnect it ,,,, do the lights still flash ???
