New bars: Electrical Issue
Old Mar 31, 2011 | 04:12 PM
skorch's Avatar
skorch
Default New bars: Electrical Issue
I was hoping to get a little help with an electrical issue im having. I just installed my apes and did the wire extensions.
The issue is that there isnt any whirl sound from the fuel pump when i turn the bike to run. all the lights turn on and there is a little movement in the speedo. the key and oil light come on also and the key eventually goes out (im assuming that the oil light would go out if i could start it?). I did siphon the tank and removed it in the process of doing the bars. Its also near empty but wasnt sure if that would stop the pump from priming.
I really dont want to rip back into my wire harness if im not even sure if its caused by my extensions.
Old Mar 31, 2011 | 04:17 PM
R_W_B's Avatar
R_W_B
Did you check your fuses?
Old Mar 31, 2011 | 04:25 PM
skorch's Avatar
skorch
yep the fuel pump fuse is fine.
Old Mar 31, 2011 | 04:30 PM
R_W_B's Avatar
R_W_B
Does the starter turn the engine over ? If not (even though the lights burn) I would check the battery terminals first. Make sure they are clean and tight.
If so then check the battery. If all that checks out then it's gonna be more fun.
(And and just to let you know I drained my tank bone dry last time I had it off and filled it back up with no problem priming the pump)
Old Mar 31, 2011 | 04:40 PM
skorch's Avatar
skorch
Yes it tries to turn over but can't I'm assuming because there's no gas
Old Mar 31, 2011 | 04:43 PM
skorch's Avatar
skorch
i havent filled it back up yet would no fuel or very little fuel cause it not to prime?
Old Mar 31, 2011 | 05:01 PM
R_W_B's Avatar
R_W_B
uh well for sure it might cause it not to prime if the fuel is low enough, not sure if it would cause the pump not to start and make noise.
When you worked on all your wiring, you disconnected the battery correct ?
Someone else will have to tell you how to test a bad fuel pump, I've never done that.
I know you are too smart for these items, but sometimes it helps just to check all the little things first before you go any further.
Make sure the fuel line disconnect is securely remounted back into position.
Make sure the on/off switch (on the bars) is on.
Oh and one time right after doing some mods on mine, the FOB battery went dead.
I have a friend that is pretty good at this stuff, and he always says to check you DTC codes in the beginning, after the obvious is done.
Maybe someone will jump in here soon with some good things to check.
Old Mar 31, 2011 | 06:29 PM
skorch's Avatar
skorch
well it looks like gas was the issue as soon as i filled it i was good to go.
Old Mar 31, 2011 | 06:48 PM
R_W_B's Avatar
R_W_B
Post
Glad you got it going.
Old Mar 31, 2011 | 07:10 PM
skorch's Avatar
skorch
haha me too, i guess this is what happens when i dont have confidence in my own work.
Grader
Oct 18, 2012 03:32 AM
Wild Billy D
Sep 13, 2011 07:17 PM
alekit
Mar 18, 2011 10:02 AM
Nightrider2
Sep 3, 2010 09:40 PM
YmeHP
Aug 22, 2009 01:06 AM
