Went to start up the wifes Sporty to move it out of the way. Turned key on, hit the run switch and fuel pump did it's thing and then I hit the start button and instantly lost all power. No lights, no nothing. Did I blow a fuse, if so which one? Thanks guys
Yep. Dead battery. The 07 & newer Sportsters have a constant power draw. I have to put my 08 on trickle charge a day before I get it out the first time each year.
another vote for the tender... if my bike is in the garage, its hooked up (and it is often my daily driver)! i like the tenders so much that i have 3 running most of the time (2 bikes and one cage).
Before you replace the battery "Check the connection". I have had the exact same thing happen twice, now I carry a small wire brush and the few sockets required in a zip lock bag on both my Sportsters (07 883L & 08 1200C).
I haven't had the problem since mid 08 because I remove the battery, clean and reinstall it when I change the oil.
Get a new Battery and a Tender.
Don't go buyin some expensive battery,, the HD AGM type
Is a goodun,,,plus It says Harley on the side XD
Shop around all you wan't, you may save 10 bucks,,
Or Just get-er-done and go ride.
