Windshield installation question
Old Apr 7, 2011 | 05:09 PM
user 62907820's Avatar
user 62907820
Default Windshield installation question
Hi all,
I am brand new to owning a bike and want to install a windshield on my 2010 Sportster XL883L Low. The directions state to remove the battery connections to prevent accidental engine startup. Is this really necessary if the key is not in the ignition?
Thank you,
Danielle
Old Apr 7, 2011 | 05:17 PM
wahlumsurfer's Avatar
wahlumsurfer
If you don't think you'll accidentally start the bike, then don't worry bout it!
It's an instruction that is usually found on any how-to guides as it's a best practice. personally I think it's more geared to the BT bikes as they some times don't require a key to start them up.
Old Apr 7, 2011 | 05:19 PM
stevelonewolf's Avatar
stevelonewolf
Remember, It's hard for someone to tell you to go against what's printed in front of you. If you accidently start the bike even with the key out and something bad happens as a result? Well it would plain suck. It's written to work two fold. 1) To protect the manufacturer from harm. 2) To protect you from harm. The choice is yours. Hope you gett'er mounted and your knees in the breeze.
Old Apr 7, 2011 | 08:45 PM
TennesseeMustangPerf's Avatar
Take a look in a regular service manual (for any vehicle). The first step is to disconnect the negative battery cable, even if it is describing how to change the cupholder insert.
How to remove the wheel
Step 1: Disconnect the negative battery cable.
How to change a headlight bulb
How to refill the washer fluid
How to disconnect the negative battery cable
Step 1: Disconnect the negative battery terminal.
Ya see where I am going with this?
Just a bunch of mumbo-jumbo to protect their backsides and make it "idiot-proof". Then again, make it idiot-proof, and the world will make a better idiot.
Old Apr 7, 2011 | 09:09 PM
wanabe's Avatar
wanabe
too many lawyers
Old Apr 7, 2011 | 09:34 PM
harley6six's Avatar
harley6six
You could just pull the maxi fuse to be safe and then plug it back in when done.
Old Apr 7, 2011 | 10:35 PM
discodave's Avatar
discodave
That sounds ridiculous. You don't need to disconnect the battery to install a windshield. Ridiculous.
Old Apr 8, 2011 | 07:47 AM
stevelonewolf
LMAO!!
JDHD06
Oct 12, 2016 08:43 AM
mississippiboy
Aug 28, 2012 09:34 PM
JamesDean
Dec 29, 2008 07:20 AM
BinIdaho
Sep 29, 2007 11:07 PM
nasumi2002
Jan 30, 2006 01:48 PM
