Clunk
Old Apr 15, 2011 | 04:19 PM
kountry's Avatar
kountry
Default Clunk
Everyone in awhile I feel and here a big clunk on the motor somewhere? Also coming from neutral to first sometimes it grinds any suggestions also I did this before I did my primary oil today.
Old Apr 15, 2011 | 07:51 PM
Scuba10jdl's Avatar
Scuba10jdl
Is it when you shift? The "clunk" is a very common symptom of the shifter dog engaging and is perfectly normal on a Sportster. The grinding is most likely caused by not hitting the shifter peg hard/fast enough. If you don't bump it in to gear quickly enough, the teeth will grind on the gears and make a nasty noise.
Old Apr 15, 2011 | 09:29 PM
kountry's Avatar
kountry
The clunk is normally after a good ride coming out of first at a stop light. It's not the shift clunk. But it feels like something in the motor and thanks for the first gear shift sound info. That only happened going from neutral to first never while in motion.
Zanthamos
Oct 21, 2015 03:34 PM
ironpineapple7
Ironhead
Mar 8, 2014 05:13 PM
Knights2TheEnd
Sep 2, 2012 02:39 PM
bezoar
Jun 17, 2008 08:15 AM
SgtThump
Nov 20, 2007 07:12 AM
